L4060 Error 92 - how to reset code?
/ L4060 Error 92 - how to reset code? #1
m0brando
Mid-MIssouri
Kubota L4060HST, Kubota Z725
I searched around but can't find that anyone else has had this problem. On my L4060 I was shredding brush and a twig pulled the wire out of the hi/lo sensor plug. This resulted in an error code 92 on the dash, beeping, and a flashing warning light. After a trip to Radio Shack for tiny wire connectors, I have soldered the wire back into the plug and plugged it back into the sensor. The beep and flashing warning light are gone and the tractor hi/lo etc seems to function fine. However if I scroll through the display options, the error 92 code is still listed. How do I clear this code? Others with similar problems on other models seem to clear the code when they fix the problem. I believe the problem is fixed, so I'm wondering if in all the wizardry of the new L-series models, they changed something to where the code has to be cleared.
thanks!
/ L4060 Error 92 - how to reset code? #2
helped a friend w/a 5030 clear the service light on the dash panel...by depressing 2 buttons on the dash & holding, forget which ones, but worth trying different combinations as a starter good luck
/ L4060 Error 92 - how to reset code? #3
Try and disconnect battery for a minute it works on autos.
/ L4060 Error 92 - how to reset code? #4
Often on off-highway the code is stored until erased using the proper software. Not sure if this applies to Kubota. It helps in trouble shooting later on to know if something unusual happened earlier in the machine's life. However the machines with which I work retain the error codes along with the hour reading at which they occurred so a technician can weed out the wheat from the chaff. Does the nook say anything? If not I would ask the dealer if only for curiosity sake.
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
Kubota M6950 (A64127)
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
