L402 FEL Float Problem
/ L402 FEL Float Problem #1
survriggs
Missouri Ozarks
Kubota B7800
Leveling driveway with B7800 and L402 FEL and using the "float" position on the FEL to backdrag. All of a sudden the joystick will not stay locked up in the "float" position, it just jumps back down. It will still work as float but I have to hold it up there...anyone had this problem before? It's only 3 wks. old so warranty will cover repair but I'm just curious before they come and pick it up tomorrow.
/ L402 FEL Float Problem #2
Here is a thread that should help with fixing Float problems. Click Here. There is one post in the thread that includes pictures of the repair.
There are several others that will help by searching for "FEL Float".
/ L402 FEL Float Problem #3
Same thing happened to mine. Detent had metal shavings in it and jammed it open. If it's under warranty sent it back. If it's broke they'll need to get another one in there anyway. Don't bother with it yourself.
I called the dealer, scheduled the situation with him and kept the tractor at the house til he was ready for it. Had it back in 2 days. More common problem that you'd think but........
/ L402 FEL Float Problem #4
Had same problem 2 weeks ago. Service guy came out with new cap that holds detent balls. When he removed old cap it was about half full of water, balls would not move. New cap that he installed had drain hole on bottom to allow moisture to drain. Seems like someone knows there is a problem.
/ L402 FEL Float Problem #5
Actually heard of this also. Some feel filling the dead space with grease is a better option. Water won't have a place to collect and the hole is subject to dirt ect.... coming in. If the hole is small enough I can't see where this would hurt
Onan 6500 Generator (A66408)
Onan 6500...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
20' One Trip Shipping Container (A66285)
20' One Trip...
Rolling Shop Table (A64127)
Rolling Shop Table...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
