L3940 - Order Spec - Tell me what I'm missing
   / L3940 - Order Spec - Tell me what I'm missing #121
That's a good point. I don't anticipate needing a trailer that often. On the other hand, I've never had one before so it's hard for me to anticipate for what I might use it. I guess if it was the right trailer and a good deal, it might be worth it--storage is always an issue.
Agreed, it is hard to tell and we have a goose neck out at our farm that hasn't moved out of its tracks in over ten years. We do use some 16' as well as a 12' and little tilt bed trailers around our farms, but a trailer big enough to haul anything bigger than one of our SCUTS just sits.
I've got a 1966 Mustang that I know I'll be hauling around a little bit in the next year. May need to haul hay if my wife gets her way and we get some horses (probably will be my penance for getting this tractor :)). In each case, I can rent or maybe borrow for a lot less than $2k total.
   / L3940 - Order Spec - Tell me what I'm missing #123
A lot of the time a equipment trailer is not car friendly due to short ramps (cars will bottom out) and the ramps are not smooth like a car trailer . A equipment trailer usually has ramps like this.
Ahh, good to know. Thanks. Dealer did say that it had fold down ramps. Suppose I could get ramps to go over those, but then I'm getting more stuff to store....
Talked with Marvin. Trailer is 7,000 GTWR. My L3940 is on the flatbed. Going to pass on it. Delivery should be Thursday unless the weather acts up.
Jinxed myself. Weather delay.:thumbdown: Better safe than sorry, though.
   / L3940 - Order Spec - Tell me what I'm missing #127
I did not see anyone mention the 10-15% tongue weight that you will be reducing your trailer weight by. That weight will then be hauled by the tow vehicle and is not on the trailer/ axles. It sounds as though you will be pushing it to the limit with the 7k trailer and with the 18' length you will not have much room to adjust/ position for the proper tongue weight. A 20 ft 10,000 lb would be a nice size as was recommended. I currently have a 18' 10,000 lb Big Tex. For me personally I can't live without a trailer. I had three different trailers of my own when I was still in New York with access to a fourth and they all got used quite often. With the amount of land and projects you have planned, I would think you are going to need a trailer, especially if you do not have a pickup. Just my :2cents: Congratulations on the tractor purchase. You are going to love it. Wish I had enough land where I am at now to justify a Grand L.
   / L3940 - Order Spec - Tell me what I'm missing #128
Just remember if you buy a trailer you also commit to everything that goes with it. In most states each year you have to pay to register it and have it inspected. Even if you never use it the tires will break down due to the elements and will need replacing before you know it. Trailers really make sense for people who use them, I would answer the question about if you would use it enough or if you can find a place to rent one when needed.
   / L3940 - Order Spec - Tell me what I'm missing #129
I agree there is some cost to owning a trailer, but it is like every other tool one owns. I have used Maine Trailer, Registration | Maine Trailer , for most of my trailers. Multiple year registration and no inspections. You would be amazed if start looking to how many Maine trailer plates are out there. I first starting registering with them when I purchased a triple axle equipment trailer (18kw) and New York state wants to charge you by the GVW. Cost was too high for my use so I went with Maine trailer. I do not see it on their website, but you could get five year plates a while back, worth looking into. As far as tires, just make sure you buy a trailer with actual trailer tires, not car/ truck tires. I have had extremely good luck, knock on wood, with all my trailer tires. Keep the tires covered or out of the sun and they will last for a very long time, and I am pretty fanatical about tires being in good condition. I think almost anyone that owns a fair amount of land and has projects will find a lot of uses for a trailer once you own one. Sort of like a tractor or backhoe. Did not realize how much you needed it until you owned it and trying to borrow or rent is just to much of a hassle. When you need it you need it. As a matter of fact, I happen to have the day off and I think I am going to run to the steel supply and pick up some 20' lengths of steel for a few projects I am working on. Your mileage may vary. Good luck in whatever you decide.
   / L3940 - Order Spec - Tell me what I'm missing #130
In VA you can get a permanent trailer tag for about what it would cost for 2 years. On a trailer under 3k gross you have the option of getting a motorcycle size plate. Anything over 3k gross has have a yearly inspection.
I decided to skip the trailer.
   / L3940 - Order Spec - Tell me what I'm missing #132
Probably a good solution, at least for the time being. It'll help to keep peace in the house too. Not like there'll never be another one at a good price, and from what we could make out, it wasn't the best match for the tractor anyway.
I'm soon in the market for a truck, and I suspect shortly after that will be a horse trailer, which is the real driving force behind the truck buy.. seeing a pattern here?? I'll look around for a flat deck trailer myself then, the 7K would be a good match for my L3400, in fact.
Sean
Here's a picture of the tractor on the truck. It's safely in the barn waiting for it's first day of "work".
   / L3940 - Order Spec - Tell me what I'm missing #134
Fun times! I like the way you "enclosed" the word work.. it sounds like you're embracing the whole concept of tractor work vs. real work. That understanding comes with membership in the Machinery Owner/Operator Secret Society of Manly Men.. very important the wimmenfolk not grasp the whole fun vs. work concept as applied to mechanized equipment.
I'd suggest practicing a few key phrases when you're sure she can't hear you.. just so you don't stumble over the words or start laughing ..
Ones like "Darn it all, the blasted driveway has drifted in again.. I guess I'm just gonna hafta go out there and clear it so you can get out tomorrow morning, honey.."..
Or "You can't be serious?? The grass in the back pasture grew again?? How high is it this time? Well, if there's no way out of it, I'll hafta take tomorrow off work and mow it.. supposed to rain cats and dogs on the weekend, ya know..",
Or my personal favourite, "That dam* Earl/George/Billy Bob down the road got seven loads of gravel delivered to his place to top dress that driveway from hel*. You know the one, I helped clear snow from it last winter! And now he's got the nerve to ask if I'll spread some of it out for him.. I tell ya, the day's comin' when I'm gonna tell Earl/George/Billy Bob to spread his own dam* gravel!!.."
Try to do it with a straight face, or it loses the effect. Once you're in the seat and that diesel's running in front of you, she won't even hear the giggle of glee as you head down the driveway. It's always worked for me, though she says I have more smile lines than ever these days. I just tell her it's old age, might soon have to look into a cab with heat and AC as I get more and more feeble. That's usually when she starts laughing and tells me to get the hel* out of the house while I'm ahead.
Nice looking rig by the way!! That belly mower on the truck must be for the BX on the trailer? For a minute there I thought you'd been forced to get the missus her own Kubota. That's a topic for another day though.
Congrats again!
Sean
   / L3940 - Order Spec - Tell me what I'm missing #136
Congrats, now we need some shots of it in action.
Working tomorrow and then temps will be in single digits w/o windchill beginning Sunday. I'm sure the tractor is tough enough to handle it, but I'm pretty sure I'm not. Might try to haul some firewood in from the woods tomorrow if I can find some time.
   / L3940 - Order Spec - Tell me what I'm missing #138
single digits spell CAB best of luck to ya
Since the temps are in the single digits I decided to build a dolly for the grapple out of the pallet that the blade was on when delivered.
It didn't take long, and the tractor was just staring at me so I decided that despite the temps I needed to do a little "work". I drove around looking for wood piles the previous owner had left and then moved the wood behind the barn so I could split it later. Had to use the FEL to pry some of the chunks that were frozen to the ground.
I was quite surprised how maneuverable it was in the woods. I was also surprised how many downed trees and such I need to clean up.
Here it is after moving three or four buckets of wood.
   / L3940 - Order Spec - Tell me what I'm missing #140
That's a darn good looking tractor! :thumbsup: what blade did you end up with?
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
Enclosed Service Truck (A55788)
Enclosed Service...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
Bobcat S740 (A57148)
204158 (A57193)
204158 (A57193)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
