L39
I don't have the quick coupler bucket, just the 18" that came with the machine. I racked the bucket and bent the side. Our weld shop fixed and reinforced the edges. My teeth are already getting banged up.
Have a few very small dings in hood. Broke the tail-light lens on a leaning tree that just caught the edge, and put a 1-1/2 hole in the grill.
I need skypups grill guard.
I keep the machine greased. Use at least half a tube each 12-15 hours, more often in dusty conditions
Under the right circumstances the loader will just barely lift he rear end off the ground. I was picking up a 7' root ball and it got scary.
I still say the bucket curl is weak compared to the rest of the machine.
I wish the machine had another 25 or so hp and weighed +10K lbs, was 6 " wider in track, and had 12.5 x 18 front tires, 17.5 X 24 rears but otherwise not more than a bit physically larger than it now is.
I would not want a full size TLB, just one almost as strong.
You my friend, have just described an L48 /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">(
)</font>
Here ya go. 67HP, fairly compact about twice as strong as an L-39 with full size TLB dig features:
http://www.jcb.com/(g5cbltz1wc0lkf55bblvk4zj)/products/productdetail.aspx?pid=110&rid=14
)</font>
Your correct, I have no L48 experience, and my only experience with hydro was on a 37 hp Deere, 3700 something. The l48 must push into a pile nice in low range.
Compared to an L39, a 8000 lb machine will have more push than a 7000 lb machine. Specs and the people I have spoken to who ran both machines say there is not a lot of BH difference between the Deere 110, L39 & L48 except a foot of reach.
The L48 Loader must be a different story as the linkage on the L48 ought to have more gaf when the bigger deeper bucket digs in than the L39. The L39 bucket ought to be 5'-6" not 72"
On industrial TLB's I've seen how Cats, Deeres , Big NH Fords put a similar size Case to shame in these tough New England soils. It's all weight, mechanical advantage, and hydraulics.
I've always liked the JCB 2C series, too bad they cost near a full size hoe.
I bought the L39 as a Swiss Army knife. I want the Snap-On Roller Tool Chest. I was at the dealer today buying some of the parts I busted and one of the guys was rolling around a KX-161 excavator. What a nice smooth 12,000 lb machine.
Mike,
Sounds like you bought the wrong machine. It's too small for your needs. Kubota brought this to market as a smaller alternative to the L48, which it is.
Mike,
Oh well, I have given up with the heavy earthmoving, and as my time is limited that I could be doing it myself and a reliable dozer and excavator are real expensive, the wife has beat it in my thick head to hire out.
I still check http://www.ironplanet.com/ and other such sites for the stupid deal. A few months ago an almost new 2005 IR 570 went for $26K in Denver Co. Seems like slim pickens this summer.
In any case my L39 Swiss Army knife makes a great landscaping & maintenance machine overall. When the place shapes up I would not want or need a larger machine.
Besides it's a fun challenge to tackle some of the stuff I have done.
You should see the driveway and wall I did with my little poor old B7200! It was the landscaping that really helped sell that property so we could get more land on the new place.
  • 902652-B7200&Rocks.pdf
I gave up on my larger machine (Ford 555 4x4 extendahoe) when I got out of the speculative home building business and went into custom building because my "mass production" ended.
What I have found is that it's cheaper to rent a trackhoe for a few days and use the L-39 to either dig footings or smaller addition foundations and do the backfilling.
I can see where brutal soil conditions would make an L-39's lighter wieght an issue, but I'm in much better digging conditions down here and I'm lovin this machine for small foundations.
Exactly.....they're great for all the finish work and medium-large landscaping jobs....perfect to dig trenches and dial in the property, but they certainly aren't "yellow" in any way shape or form. I can rent big stuff not too far down the road without insurance (excavators/dozers etc.) so that's what I do. No more killing myself and the machine doing work it wasn't designed for.
BushHog 2615L 15ft Batwing Rotary Cutter (A65640)
BushHog 2615L 15ft...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
QLF Lick Tank (A66408)
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
