L39 Steering Controller Leak
/ L39 Steering Controller Leak #1
Jim Miller
Kerrville, TX
2019 Kubota M62 TLB, Bobcat T 650 Trac Steer
My L39 has a small hydro. leak at the very top of the Steering Controller Box where the steering wheel U-Joint shaft goes into the box. The leak is coming from under the spring clip. Has anyone had a similar problem and is it a simple fix? I was hoping that I could remove the u-joint assembly and take the spring clip out and hopefully see an O-Ring that might be worn. The leak isn't really bad - yet!
I didn't want to remove the Steering Controller Box and all the hoses if there is a simple - easy - way to get to it.
I will really appreciate any advice.
Bump - I would appreciate any help or suggestions.
Thanks!
/ L39 Steering Controller Leak #3
I wish I could give you advice, my manuals are in CT and I am in NH until Thursday. I can look and see if there is a diagram them if you want.
I am curious how many hrs you have on it.
I have 868 hrs and I got it used a year ago. I absolutely love this backhoe. The leak or "seep" just started about a month ago and I just stuffed a rag around it until I can determine what to do. I check the fluid every weekend and still haven't added a drop. Not a single thing else wrong. Works hard every weekend rebuilding a creek bank.
What I may do is remove the steering universal joint and the circle snap ring on top of the controller and see if I can determine where the fluid is coming from. I'm not going to start removing valves inside the controller housing. If it comes to it, I could remove the whole controller and take it to the dealer and let them rebuild it.
Thanks!
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2020 BOBCAT E50 EXCAVATOR (A64279)
2020 BOBCAT E50...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
