L39 power beyond
/ L39 power beyond #1
fritoman4
Hi, Long time lurker, first time poster. I am in the process of installing a W R Lond 3rd function kit to power my grapple. Where exactly is the Power beyond on my loader valve? Thank you in advance!
/ L39 power beyond #2
If your valve is equiped with a power beyond option it would be on the side with the return to tank. Some valves you can just use the return port, and other valves you have to install a power beyond fitting. This is used to prevent the return cavity from cracking under the pressure down stream.
/ L39 power beyond #3
I am surprised that the kit from WR Long did not come with the instructions showing the hook-up. Give Nelson a call at WR Long I am sure he can help you.
MarkV
/ L39 power beyond #4
Welcome to TBN:D
The port is usually labeled PB or just B.
/ L39 power beyond
Thanks to all that replied. I called Nelson and was very helpful! Now I've got to get it hooked up and play, er I mean work. Thanks again
PALLET OF TRASH PUMPS (A67714)
PALLET OF TRASH...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
2012 Mitsubishi Fuso FEC72S Box Truck (A66736)
2012 Mitsubishi...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
