L39 or JD 110 tlb
   / L39 or JD 110 tlb #1
spo307
Levittown & Long Eddy NY
kubota L4400
I have been reading for sometime now, great site:) I am looking to get a tlb for my property, 58 acres, I have a 7' alamo flail, to mow about 13 acres, the backhoe is needed for tree replanting to close up some of the 13 acres, maintaining logging roads etc, maybe dig a pond, I like kubotas and have ran several excavators, I have ran cat 446 & 426, I really like the L39. I just want to ask for your opinions, which is a better machine for what I described, kubota L39, or john deere 110 thank in advance for the opionons
   / L39 or JD 110 tlb #2
Have you considered an L-48? Comparable in price to a 110, but might be a little "harder" and a little more powerful. Compare the PTO HP8 ios 37.5 the 110 is only 33. That extra PTO HP will come in handy for your mower. The engine is 5 more HP (12% more)
The L-39 is a smaller shuttle shift tractor. The 110 is a hydrostatic, like the L-48.
The 110, IMO, is more like a small backhoe. The loader & backhoe controls are more like a real dedicated backhoe. It has the creep feature which allows movement from the backhoe seat. It has the side instrument panel. It seems more like a construction site machine when I used it. The L-48 seems like more of an all-around machine for farm or landscape construction.
The L-39 doesn't have the creep feature, it's smaller and less powerful, but it's also less expensive. I owned one for 1 year. I liked it, but it was the wrong machine for me. I didn't like the soft, thin sheetmetal on the hood. The front tires are smallish. Otherwise it's typical Kubota-tough and well engineered.
I guess what I'm saying is to check out the L-48, you might find it to be a better comparison to the 110 than the L-39.
   / L39 or JD 110 tlb #3
I do not own either, and would say that they are both very good tractors for the size. But would think that you would go for a larger machine... They are fairly small tractors and I would think you will rapidly outgrow. Which will cost you $ when you want to trade up in 9 months.
Maybe you should look at the bota M series or the 52** JD series. They are just a little larger with a lot more capacity.
just 2 cents worth
good luck
Joe
   / L39 or JD 110 tlb #4
If you're open to another plan, I too would consider a nice old Case 580E or SuperK 4x4 backhoe for about $20 grand and a nice used 60HP 4x4 farm tractor for mowing for about $15 grand. That way you can have 2 MUCH bigger machines with so much more power & capability. I can tell you with personal hands on experience with both, that my L-39 was just a toy compared to my Case 580.
Here's a comparison of the L-48 and the JD 110
http://www.kubota.com/f/products/l48_comps.pdf
   / L39 or JD 110 tlb
I know theres no comparrison between a L39 and a cat 426 4x4 hoe, I was just trying to get it all in one machine, you point sounds good a full size backhoe and a tractor for the flail mower
   / L39 or JD 110 tlb #7
No problem. I just saw the size of your property and the fact that you want to dig a pond and thought you might be better off with 2 bigger used machines. IMO, those compact TLB's are too expensive for what you get. Been there/ done that.
You can get a 3000 hr used full size 4x4 TLB with a cab for 20 grand if you look a little.
-CASE-580 Super K-glenolden-PA
1987-CASE-580k-Grand Blanc-MI
1994-Case-590-Berwick-PA
You could get a real nice 4x4 farm tractor for ~15K:
http://www.tractorhouse.com/listings/detail.aspx?OHID=5320191&guid=67312951E7AD4255A006E0720339DFB7
http://www.tractorhouse.com/listings/detail.aspx?OHID=5318920&guid=67312951E7AD4255A006E0720339DFB7
   / L39 or JD 110 tlb #8
RAT, a poster here, purchase a new L-48 when the production started; he liked every thing about the tractor, except the HST gearing wasn't suitable for mowing, and ended up selling it! The low was too low, and the mid-range too high, I think?
   / L39 or JD 110 tlb #9
I had heard that too, but you have to remember the 110 is also a 3 range HST trans like the L-48. So both may suffer that same fault depending on speeds in each range.
I'm just turned off by small TLB's after owning one compared to full size machines. The work output/dollar is so much better with a full size and 3000-5000 hrs on a quality brand full size is nothing. A small TLB would be getting close to worn-out.
Livestock Stall Fan Cage (A50515)
Livestock Stall...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
72In FEL HD Round Back Bucket (A52128)
72In FEL HD Round...
