L3800 storage size
/ L3800 storage size #1
redsox1
Central Massachusetts
L3800 HST
I'm waiting on delivery of a L3800 w/ BH77 BH and am trying to plan where to store it between uses. If it will fit I'd like to put in in a garage bay, but if thats not possible then I'll have to build a medium sized storage building. My question is what is the size of it's parked footprint, i.e. dimensions parked w/ BH bucket down on floor. Plus I need to know the height requirements for driving it into the bay w/ the BH partially raised. I believe the dimensions for the L3200 & L3800 are exactly the same (just a slightly bigger engine displacement for the L3800). They are relatively new models but are there any owners out there that can help w/ the size issue? Thanks, can't wait for delivery.
/ L3800 storage size #2
Call your dealer! He should know and if not! You paid him enough to go out and measure it for you! :)
Congratulations on the new tractor:thumbsup:
/ L3800 storage size #3
I have a friend thats puts his L3700su with BH 77 in a one bay of a little two car unit, it fits withthe BH turned side ways after getting in inorder for the fel to fit, he backs it in. I will post a photo as soon as I can find it, I have over 100,000 photos on this computer, and the one I want, is the one that is hiding
/ L3800 storage size #4
I found the photo. Also note it fits with lots of other stuff, that is a full size van in the other bay. Hope this helps.
Thanks, looks like the short time solution to keep it in an available garage bay will work.
/ L3800 storage size #6
I need 19' to just barely fit the L3800 + BH + loader arms, with quick-attach bucket removed. So, lots of depth is a good thing!
The ROPS-down position limits the height. I just fit into a 6' log-barn doorway with the ROPS down. The BH can be manoeuvred in that space.
Width depends on your FEL bucket - normally 66", I think. You want at least 6" on either side beyond that.
If I understand you right it sounds like I'll need about 21' in length if I want to keep the bucket on, I do have the 66" quick release. Height should be Ok even w/ the ROPS up. I'm at work now so I'll have to measure things up when I get home. Thanks for the info.
/ L3800 storage size #8
If you do not have enough length or want to save some room, turn the BH sideways. Just remember before you drive out to adjust it back to normal position!
