Buying Advice L3800 or MX4700 or MX5100?
   / L3800 or MX4700 or MX5100? #1
ravencr
Bronze Member
Des Moines, IA
TBD
Hey guys,
I've never owned a tractor, but we just bought an RV Park and need a tractor to do the following things around the park:
1) Spread Mulch
2) Spread Pea Gravel
3) Spread Gravel for Roads
4) Grade Roads
5) Create new roads and sites
6) Bushhog
7) Spray grass and sites
It sits on roughly 20 acres, and the majority of the time will be used to grade the roads and sites, spray, and bushhog. I was told by my local dealer after looking at both the L3200/3800 and the MX5100's that all I'd probably need is the 3800, so save the money. My only challenge with this is that I'd hate to regret the decision and wished in short time that I had bought the larger MX4700 or MX5100. I spoke to a dealer today that said the only time he gets people trading late model units in is when they bought too small of a machine, because he said they basically will last as long as I'd like it to with proper maintenance.
So, any recommendations from those that have had this dilemma before?
Also, I have some questions on what options to get and what they are, specifically the optional valves, 3 point stabilizer kit, whether the rear work light is worth it, cruise control worth it, rear wheel weights and/or ballast box, what a drawbar clevis is, and whether the sunshade with lights is worth it??
Also, as far as attachments go, is the bolt-on cutting edge worth it/what does it do? Also, it showed a quick disconnect loader yesterday on the website, but now it doesn't. Which one is the most heavy duty and easiest to work with? And, are the extended warranties on the tractor and loader worth the money? For grading gravel roads, what would you guys recommend buying: a box blade or single blade or something else all together? I was told the landpride attachments can be lumped into the same kubota 0% financing, so I was hoping to pick it all up at once.
Also, being in Iowa, anyone have a great recommendation on where I could get the best deal on one of these tractors? What's a normal discount off the suggested retail prices on kubota.com?
Thanks in advance for the help guys...I really appreciate it.
Chris
   / L3800 or MX4700 or MX5100? #2
I don't know about the specific bota models (others will chime in) but from the tasks you list I would think that the bushhog size desired will guide you to the correct tractor/HP size. How much of the 20 ac will be cut and how fast do you want to cut it?
The cutting edge bar bolts onto the front of the FEL and is worth the extra $$. The add a lot of strength and protection to the bucket and are a lot cheaper than a bucket to replace. Mine has a double edge so if I ever trash the leading edge, I can simply flip it over and have a fresh edge again.
Actually the bushogging is only a minor part of what we'll use it for. There's a back section of only a few acres that I'd like to use the bushhog for only. The rest we cut with zero turns.
Thanks for the info on the cutting edge. Sounds like it's a worthwhile thing to have initially.
Chris
   / L3800 or MX4700 or MX5100? #4
There is an active thread on L3800 and the "jerky hitch", so before buying one have them put a rotary cutter on the tractor and raise it slowly to see if it is something with which you can live.
I agree with wannabeRetired about the bolt on cutting edge.
As for road maintenance and creating roads, it is hard to beat a good hydraulic back blade, but they are expensive. Top and Tilt helps also if you can swing the hydraulic blade, but again $$$$. There are posters on here who know a lot more about roads than I so hopefully they will show up. I use a combination of box blade, drag scraper and back blade.
If I was buying, I would be looking at a L3540 as it has a great 3PH and lots of options.
The L3800 will be big enough as much as I like more power, I see no need for anything bigger as nice as the 4700 and 5100 are.
   / L3800 or MX4700 or MX5100? #5
I would even say an L3200 is more than enough power for what you are looking for... but with the jerky 3ph... grading is a nightmare. You want to adjust a little bit but the valve will move an inch. I can not recommend a L3800 or a L3200.
The other two tractors are oversized. I would look at another color or the "B" series if you want Orange. In fact you might like the smaller size to get into tighter spots... I assume you have a few tree?
So, I'm so confused with all these numbers, physical size differences, etc. Where does the L3540 fall into the physical size and hp wise compared to the L3800 and MX5100?
A jerky 3PH doesn't sound great, that's for sure. I prefer saving money where I can, but obviously want something to get the job done too. The B series tractors look like a toy to me.
Chris
   / L3800 or MX4700 or MX5100? #7
Don't overlook the L4400, it's in between sizes of the L3800 and MX4700, and doesn't have some of the downfalls that the L3800 has (3pt hitch). As far as physical size goes it's closer to the MX than the L3800. Also probably a little cheaper than the MX4700 too. As mentioned before, also look at the Grand L's. I would personally rather have a L3240 vs a L3800 even though the L3800 has more power. Even the small grand L's are considerably heavier than the standard L's.
As far as options, the 3pt stabilizer kit will make your life much easier, it uses slides instead of turnbuckles to adjust side play on the 3pt, and saves a lot of time/frustration. If it's a hydrostatic and you'll be doing much mowing go for the cruise control also. Rear wheel weights are always good, we order at least a set or two on every tractor we get (and fill the tires), more weight = more traction. Having rear remote valves is nice if you have a need for them.
I would skip the work light as they are way overpriced from Kubota, basically the same thing can be had from a local farm store for $10-15. Skip the draw bar clevis, very very few implements in this country use that type of hitch. Unless you use the tractor for hundreds of hours of loader work, mostly on hard surfaces, you'll never see the benefit of the bolt on cutting edge (designed for added wear resistance) No need for the extended warranty either, unless you just like throwing money away.
As far as attachments go there are a lot of good options that will do what you need. A box blade and landscape rake would be a good combination for building and maintaining roads. However, as far as ease of use for gravel road maintenance you can't beat one of these new grading scrapers (two diagonal blades inside a box that stir up the gravel). From what I have seen they work great for repairing and maintaining roads, but not as versatile as the box blade/landscape rake combo.
For the L3800 you'd be looking for a 5' bush hog, 5-6' box blade and 6-7' landscape rake, or about a 6' grading scraper. For the L4400, MX4700, etc you'd be in the 6' bush hog, 6' box blade, 7-8' landscape rake range.
   / L3800 or MX4700 or MX5100? #8
I maintain my dense grade with a landscape rake. If its really bad I use my grading blade first. But the landscape rake leaves such a nice top layer. If you will be installing loam the rake is a must have. Since the rake has wheels, and the blade has skid shoes, the L3800 jerky 3 pt hitch would likely not be a issue. The B's are really nice for smaller areas. The Grand L's are $5-$6,000 more. I don't think the B's would suit you though. For sure get a bolt on edge, as well as a heavy duty bucket. For sure get the wheel weights. They are a way underlooked, effective item. And getting them new, with the tractor, is way easier than finding them years later, as I found out. The rimgaurd would also likely be a good buy. If you don't mind used, the Kubota L3410, L3710, L4310, L4610. They are excellent tractors, with powerful hydraulics and very few electronics. I have a 2002, L3710. I would not trade it for a new one. One of my favorites.
   / L3800 or MX4700 or MX5100? #9
First don't underestimate the B (or the BX, for that matter) it will get the job done... maybe a little slower...
I went to look at something you wrote and see that Verticaltrx added very good comments... the L3540 falls in between... It has a smooth 3ph and deluxe features that the "economy" line of the L3800 doesn't have.
Going into the L4400... it's big and powerful... my guess it's more than you need.
I'm still thinking a large B would fit the bill... :2cents:
Take your time looking for the right tractor... test drive may of them.
   / L3800 or MX4700 or MX5100? #10
If the physical size is not an issue for you then I would get the MX5100 which gives you a bigger more capable loader and extra HP. HP can always be used if it is there but only dreamed about if it is not there.:thumbsup:
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
2018 Ford F-150 Ext. Cab Pickup Truck (A46684)
2018 Ford F-150...
2017 Bobcat E85 Midi Excavator (A46683)
2017 Bobcat E85...
2015 Kia Sorento SUV (A46684)
2015 Kia Sorento...
45007 (A48082)
45007 (A48082)
Kivel 48in Pallet Fork Attachment (A49251)
Kivel 48in Pallet...
