L3750 Shifting Problems
   / L3750 Shifting Problems #1
Davaron
OK, I have a shifting problem. Checked the archives and did not finds a suitable reference. I have a 1987 L3750. It has the the gear selection on the right side of the seat and the hi/lo and forward/reverse on the left. Tractor is stuck in 2/6 gear. Shifter will not move out of this gear. Tractor runs fine and will operate in either 2nd or 6th gear depending on the range and it operates forward and reverse. It will just not come out of 2/6. PTO works as well.
Any suggestions? Thanks or any help.
   / L3750 Shifting Problems #2
Yes, you have sheared the roll pin on the main shifter lever, very common failure. Remove the seat pan and the sheet metal around the shifter on the right side of the seat. The remove the shifter housing. You'll have to line up the shaft, the shifter, and the breather hole, then drive the pieces of the broken roll pin out. Kubota had upgraded those parts years ago to a solid pin. Instead of buying the Kubota parts I just drill out the shifter and shaft to 1/4" and use some hardened rod from the hardware store cut to length. Then I cut my own cir-clip groove in the shifter to keep the pin from being able to fall out. You'll probably have to talk to a pretty experienced Kubota parts guy for him to be able to get you the updated drawing unless Kubota has managed to put this in their electronic parts manuals, otherwise he is likely to just have the old style with the roll pin and safety wire.
Brian
So you remove the 4 bolts from the housing and everything just lifts off? Sounds pretty straight forward. Any little hidden things to be on the look out for? Is there a casket to replace? I plan to use it as is for the weekend and then get parts the first of the week.
Thanks
   / L3750 Shifting Problems #4
The gasket is a square cut o-ring which you should be able to reuse, there are detent springs under the cover but typically they stay with the machine.
Brian
Thanks so much for the help. I will let you know the outcome.
Ok, Turns out that the roller pin was bad but the worst of the deal was that the shifter rod itself was seized up in the housing. No lub could free it so I had to purchase a new housing and roller pin. $300 and we are back rolling. Moral of the story... Keep your tractor sheltered. Moisure seems to have been the culprit.
Thanks for all the help
   / L3750 Shifting Problems #7
I recently had a similar problem with my son's L3750, but after following your instructions, I find that the roll pin is not broken. Also, I can line everything up & put it back together and it will shift a couple of times, then nothing again. It's as if the shifter mechanism is missing something to keep everything lined up. Any insights?
   / L3750 Shifting Problems #8
Sounds like another pin or a detent is causing a hang-up. Each side needs to click into the centered position for the other to move. If the main pin is ok, check the other pins, rails, detent balls, springs etc. If you're lucky no parts will drop into the case :)
  • L3 shifter .pdf
   / L3750 Shifting Problems #9
Thanks rbargeron, but I checked the forks, and their pins as well. If one is very careful lining up the neutral position, you can proceed to the next gate, but it's almost as if the shifter lever (inside) is not moving the slide far enough. It doesn't appear to be bent or excessively worn. Just general wear maybe?
   / L3750 Shifting Problems #10
What are the symptoms on this machine? I've often gone right by something that looked ok - but wasn't. How's the top shifter shaft for wear and/or rust? Keep looking, you'll find it.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
Pallet of Misc Stihl Power Tool Components (A56860)
Pallet of Misc...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
Billy Goat Multi-Vacuum (A56860)
Billy Goat...
