L3750 Hydraulic Filter. Need expert help!
   / L3750 Hydraulic Filter. Need expert help!
How many filter does your tractor have? Some require 2. Some filters are on the pressure side so you do not want to use the wrong filter. It will rupture if not the proper filter.
It only has the one.
   / L3750 Hydraulic Filter. Need expert help! #12
I come up with the old number also and sells for just over $28.00. show a picture of yours because the old # doesn't look like the new filters.
   / L3750 Hydraulic Filter. Need expert help! #13
Kubota dealer says that the 36330-82630 and HH330-86230 are the same just an updated sku.
They may be the same, or it may be an error (I show the HH330-86230 to be for a different tractor - mainly M Series). I will look into it a little bit more and get back to you. Maybe my parts guy knows something.
   / L3750 Hydraulic Filter. Need expert help! #14
These are different filters. The "HH" filter is larger with a larger diameter thread on it. There must be an issue with the suppression in Kubota parts program. Have the dealer order the exact 36330-82630. IMG_1223 (2).jpgIMG_1224 (1).jpgIMG_1225 (2).jpg
  • Filter 1.pdf
  • Filter 2.pdf
  • Filter 3.pdf
   / L3750 Hydraulic Filter. Need expert help! #15
Using Messick's it is fairly easy to check part numbers. Please keep in mind I'm not certain if this is a L3750, L3750DT or L3750F. Using the "frequently used parts" L3750DT the following appear. It indicates 36330-82630 is the correct part number.
If you're interested in the WIX equivalents...
Details of the hydraulic filter:
View attachment 458334 and View attachment 458338
Thanks Moship and Texas Fella and all of you guys that helped. My manual and the Kubota website all said the filter was 36330-82630. 2 different dealers said that the SKU was changed to HH330-82630 which is of course the wrong filter. I went to dealer number 3 and got the 36330-82630 in today and it works great. Imagine that. Striking it up to uneducated parts guys and me not knowing any better. Thanks for all you help! you guys are great!
   / L3750 Hydraulic Filter. Need expert help! #17
Glad to see that got worked out. Shoulda been simple, but... a fairly logical confusion with those similar numbers, though.
John Deere 5090GN (A60462)
John Deere 5090GN...
2022 John Deere 1025R (A53317)
2022 John Deere...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
