L3710HSTC Problem
/ L3710HSTC Problem #1
Electroman
Val des Monts, Canada
Kubota L3710HSTC
Hi everyone!
I am new on this forum, I just bought a 2001 Kubota L3710HSTC tractor with a L682 Loader on it, It have 880Hrs on it and i thinks i have a some problem with it, i'll explain:
First:
When i start the tractor (at -15C), i turn the ignition switch on, the glow plug lite for 4-5sec and after that they turn off, i crank the engine and it take about 10-15sec to start.
when the engine start, there's a lot of black smoke for 2-3sec and after, the engine idle very well and respond to the trottle perfectly.
I think that the glow plug dont have the time to get hot enough in 4-5 sec at that temperature, is there a way to make them lite longer or it is always 4-5 sec??
Second:
The tractor hydraulic and hydrostatic are working good but it is making a strange noise (weird whining or buzzing noise of some kind) coming from somewhere around the hydrostatic unit when i release the clutch (without moving and touching the speed pedal)
The sound is similar to an hydraulic pump running on relief BUT
The hydraulic for the loader work well and have power and speed.
The hydrostatic trans work very well in every range and reverse.
The 3 point work well too at any position and have the power it is supposed to have.
Hydraulic fluid is Full.
The tractor is working well but this noise is loud and anoying.
If any of you have saw something like that before, it would be nice to know what could cause that noise.
/ L3710HSTC Problem #2
I have an L3710 HST and go from off to glow plug on the ignition switch about 4-5 times before I attempt to engage the starter. The time is goverened by temperature but I've always felt is was simply too short. You'll notice that after the tractor has been running for a while and you shut it off, turning it back on the glow plug time is pretty short if at all.
P.S. My unit does tend to whine but it has never bothered me and I've had it for 8 years. My unit is an open station so maybe the cab has something to do with the level of the whine.
6ft Metal Star (A65583)
6ft Metal Star...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
19-gallon Portable Sandblasting Cabinet (A66408)
19-gallon Portable...
