L3710 won't start
   / L3710 won't start #11
Make sure the PTO is off and the range lever is in neutral. I had a stick get stuck in one of the safety switches and caused this very problem. Those safety switches will keep it from turning over.
   / L3710 won't start
I used the Idea of jump starting by running a jumper from the positive side of the battery to the solenoid contact with the key on. When I touched the jumper wire to the wire I had put on the solenoid it sparked bad an melted the end of my wire?
   / L3710 won't start #13
Did you make good contact with the
wires?? You can melt the post on a
battery if you do not make good contact
like putting a clamp on makes good
contact no sparks etc.
But then again if you have a dead short
you can melt the wires
willy
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2003 Big Tex 10PI...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
1995 John Deere 7400 (A60462)
1995 John Deere...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
John Deere 5100M (A53317)
John Deere 5100M...
