L3710 Will not Lift Front End
   / L3710 Will not Lift Front End #21
Please find another dealer that is not trying to scam you.
Highly unlikely that you need a new pump, but even if you did, that's like around $1300 or so. Kubota L3901HST (4WD TRA W/HYD TRANS/FOLD ROPS) Parts Diagrams
I wish it was as simple as that. do some checking and get back to me. If you can find a better price please let me know. I am patiently awaiting your info...
It IS as simple as that. Either you have misplaced a zero, or your dealer did.
Diagnosing the cause of low power hydraulics is pretty easily done on a stock tractor. There are standard places to check flow and pressure. Repairs might cost a couple of thousand and for that you would know exactly what to expect.
But first you need to see a mechanic's shop report showing the pressures and flow rates at the standard check points along with his best estimate.
rScotty
Maybe it's Hong Kong dollars.
   / L3710 Will not Lift Front End #23
In Missouri we say "Show Me!"
As a kid growing up in Vermont we use to say "try it, you may like it" ...
Either way I've found it's the best way to learn!
SW Mo here as well!
I'd rather not say what the problem turned out to be.
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
