L3710 Will not Lift Front End
   / L3710 Will not Lift Front End #1
Suburban Plowboy
Platinum Member
FL
Kubota L3710
I put two rear remotes on my L3710 HST. It lifts things like logs just like it always did, but it will not raise the tractor's front wheels when I push it down.
What is the most likely problem?
   / L3710 Will not Lift Front End #2
Hard to say. What did you add and how/where did you add it? Something obviously changed if it raised the front end before the addition. More details or a lot of wild guesses come next.
I don't have a habit of lifting the front end with the bucket, having little reason to do so, so I am not positive, but I believe it was possible to lift it before I installed the new valves.
I'm going to make sure the fluid is topped off, and I will also go through the air-bleeding procedure I saw somewhere.
   / L3710 Will not Lift Front End #4
In most cases bleeding won't be necessary. What exactly are we doing here? Are you looking for answers concerning a problem you're "not positive" you even have? I don't know about others, but when I have questions about hydraulics, lifting or not lifting as expected I start with a pressure gauge plugged into a coupler somewhere, and see what that tells me.
   / L3710 Will not Lift Front End #5
If youre incidentally holding the brake when trying to lift .. dont.
   / L3710 Will not Lift Front End #6
When you try to lift the front, are you putting the loader all the way down, and then curling the bucket like you want to dump a load?
The hydraulic system should self-bleed.
I did not try to curl the bucket.
I will get back on this tomorrow. I am hoping my bearings and seal will be here by then.
I don't hold the brake. I can't recall ever using the brake. On this farm, I never need it.
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
JMR stump/trenching bucket (A53421)
JMR...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
