Price Check L3710 pricing
/ L3710 pricing #1
mr_ed
I've been checking on pricing for a L3710 4wd gst. Local dealers hitting it around $14700-14800 tractor only. Heavy duty 5ft bush hog with 110hp gearbox $1325-1400, and fel $3550-4000. any suggestions appreciated. i have about 300 acres to play with, about 150 that needs bush hogged and has 1-4 inch saplings. will this be heavy duty enough. I will be bush hogging in between rows of oak trees, and don't want to cut them down, just get rid of the gum trees so the oaks will grow faster. also will want to use it for making food plots. another note, is there an aftermarket fel any cheaper that will work with this setup, or should i go with a factory fel. thank you in advance.
/ L3710 pricing #2
I would give Carver Equipment a look to see if they can get you a better deal. There prices are unbeatable. I would have gotten mine from them but the diffrence was 500. Also they don't tax if it is out of state. That usually makes up for most of the shipping charges. Where are you located? From what I have read we have people all over and someone may know of a dealer closer with good prices.
/ L3710 pricing
i live in arkansas, and as far as the sales tax issue, it should not be a problem. the way i understand it if you have over so many acres then it is tax exempt. thank you for your response. i like the idea about carvers, but them being in north carolina is a little too far to drive for me.
/ L3710 pricing #4
As of April 1, Kubota has a new Promotion. There is a $1400 rebate on the L3710, L4310, and L4610. After April 15 Kubota will change the way it discounts to dealers so prices may rise by $400 on tractors purchased after that date.
I just ordered an L4610 with HST, FEL, Long 4n1 with toothbar, R4's, ATI skidsteer QA, and a HD Hardee 6' B-hog yesterday while I was home sick with the FLU! Delerium has its advantages. I was able to use several Out of State quotations to get my dealer in the ballpark. For me, Carver was a little on the high side.
Approximately 2 week delivery. I can't wait.
According to my local dealer, the L4610 is allocated; so I'm a little confused on why they're offering the rebate unless a facelift is in the works.
SEE: http://www.kubota.com/rebate.cfm for details.
You may want to look at the L4310 for a little more power, especially on the larger brush.
Best of Luck,
John
Rooster Weather Vane (A64127)
Rooster Weather...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
Four (4) John Deere 8R Front Fenders (A65640)
Four (4) John...
International 2000 End Loader (A66408)
International 2000...
Location Info Please
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
