L3710 and la681 loader weight?
   / L3710 and la681 loader weight? #1
nyone
Elite Member
Ford 851
Looking at a tractor loader combo but i need to beable to move the thing.
Do my numbers look correct here?
L3710 Tractor 3500lbs
La681 Loader 800lbs? Its the quick detach version
Two 14.9x24 rear tires that i would expect to be loaded. 400lbs each.
That puts me right at 5000lbs.
No one even knows the approximate weight of just the loader?
   / L3710 and la681 loader weight? #3
There are options for a 3710 which affect the weight.
Tractordata.com provides you with some info on the tractor alone.
A hydro cab dry weight is 3,490 lbs including approx 500# for the cab. Add fuels and oils.
TractorData.com Kubota L371 tractor dimensions information
Loader and bucket would be approx 850#.
If you have a loader then you will need to have some form of rear ballast which needs to be taken into consideration if you are looking for a weight to be hauled.
Dave M7040
Thanks dave. It has a aftermarket cab with soft sides so im sure thst cant weight 500lbs. Il be just able to move this with my current trailer.
   / L3710 and la681 loader weight? #5
Make sure you got good brakes on both the trailer and truck, a good brake controller, and minimally a 3/4 ton truck. Preferably a 1 ton truck.
I got that covered. I have been towing my mini excavator 3hrs through the mountians for a few months now. I own a piece of property north of me.
Yukon xl 2500, brake controler and car trailer with new brakes last year.
   / L3710 and la681 loader weight? #7
Current Grand loaders are 1,200lbs or so. I'm guessing that includes a bucket. Probably a similar ballpark to an old Grand loader.
Geismar powered by Stihl (A56435)
Geismar powered by...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
