L3710 and la681 loader weight?
   / L3710 and la681 loader weight? #1
nyone
Elite Member
Ford 851
Looking at a tractor loader combo but i need to beable to move the thing.
Do my numbers look correct here?
L3710 Tractor 3500lbs
La681 Loader 800lbs? Its the quick detach version
Two 14.9x24 rear tires that i would expect to be loaded. 400lbs each.
That puts me right at 5000lbs.
No one even knows the approximate weight of just the loader?
   / L3710 and la681 loader weight? #3
There are options for a 3710 which affect the weight.
Tractordata.com provides you with some info on the tractor alone.
A hydro cab dry weight is 3,490 lbs including approx 500# for the cab. Add fuels and oils.
TractorData.com Kubota L371 tractor dimensions information
Loader and bucket would be approx 850#.
If you have a loader then you will need to have some form of rear ballast which needs to be taken into consideration if you are looking for a weight to be hauled.
Dave M7040
Thanks dave. It has a aftermarket cab with soft sides so im sure thst cant weight 500lbs. Il be just able to move this with my current trailer.
   / L3710 and la681 loader weight? #5
Make sure you got good brakes on both the trailer and truck, a good brake controller, and minimally a 3/4 ton truck. Preferably a 1 ton truck.
I got that covered. I have been towing my mini excavator 3hrs through the mountians for a few months now. I own a piece of property north of me.
Yukon xl 2500, brake controler and car trailer with new brakes last year.
   / L3710 and la681 loader weight? #7
Current Grand loaders are 1,200lbs or so. I'm guessing that includes a bucket. Probably a similar ballpark to an old Grand loader.
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
202479 (A54757)
202479 (A54757)
FUEL CELL (A58214)
FUEL CELL (A58214)
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2019...
