L3650 Clutch issue
   / L3650 Clutch issue
I think on that model series there were three clutch setups. A single dry clutch was standard, or options were the dual dry clutch or a hydraulic wet clutch (Ever Clutch). The L3650 was the "later" model and by that time the single clutch wasn't offered. Maybe if somebody knows otherwise they'll chime in. As always, cheerful refund if info given by me is bogus :)
I just realized I have an ever clutch. Will this make a difference?
   / L3650 Clutch issue #12
Yes - quite a difference - are there a EC labels on the sides? It might be time to post the serial number so someone can tell you what the build sheet says. Have you owned it since new?
The ever clutch is really two independant clutch packs - if drag develops it usually affects forward and reverse differently. Most common failure is warped slip rings from excessive slipping. More background reading here.
I haven’t owned it since new. It does have the decals on the fender for the ever clutch. Thanks for the link.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2315 (A58376)
2315 (A58376)
CASE 580K CONSTRUCTION KING BACKHOE (A52709)
CASE 580K...
2018 Ford Transit 150 Cargo Van (A56858)
2018 Ford Transit...
Portable Gantry Crane w/ 5 Ton Chain Hoist, 9' W x 12'H (A59076)
Portable Gantry...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
