l35
Brian m
Barrie ONT CANADA
2002 kubota L35
New tractor to me. 2002 l35 1500hours very well looked after.
Any thoughts on maintance right away before I do any heavy work?
thanks Brian
I would do the obvious:
engine oil / filter change
hydraulic oil / filter change
grease everything
At least you will have a known starting point for maintenance
/ l35
Thank for the advice. I cant wait to use this thing. I do plane on changing all fluids before I get busy!
Brian
After you change the fluids....get to work and have fun!
Brian
Congrats on your L35. :thumbsup: I just got a used one a few weeks ago and am really digging it. Was told by a member here to immediatly check the front axle oil level. It was indeed a little low so be sure to check yours. I did the full service on mine including fuel filter. WOW, that Kubota hydrolic/trans oil was expensive. $88 for 5 gallons. :( It takes about 10 gallons. Followed the manual and all the servicing was fairly simple.
/ l35
Thanks guys
I did all the sevice also except the gear oil in the front axle. I will do that on monday!
LOVE THE TRACTOR!
