Tires L35 Tires
   / L35 Tires #41
Re: Front axle seals
O.K. Daren here's what I think you may be experiencing:
When you have a bucket full of material and your dumping, the weight of the material tends to cause the bucket to dump faster than if it was empty. This will create a slight air void inside your cylinders. Thus the 'spongy" effect you describe. The increased speed of the bucket dumping exceeds the ability of the cylinder to completely fill on the opposite side. When you power the bucket in the other direction you basically purge the air and the cylinders are tight again. Most likely the same thing with your backhoe just shows up as a different symptom do to the working nature of the two different implements. I can't remember if it was an option in 1996 but they have overcome this problem with a new style loader valve (4 position), That adds a regeneration circuit which ports fluid to both sides of the cylinder and eliminates this effect. I know, if you port fluid to both sides of the cylinder how does that work? Why does'nt it just lock up and not move? I'ts simple once you think about it for a minute. The front side of the cylinder has the rod in it, while the back side does'nt, therefore due to the larger displacement on the backside it overcomes the front side and no more air bubble.
   / L35 Tires #42
Wow, sounds very knowledgeable and wish I would of known all that before. /w3tcompact/icons/smile.gif Thank you and I hope that this 1996 didn't have that option installed because then I will have to find something else wrong. Probably for the cost of this option upgrade I could live with the few instances that this takes place unless it causes damage or something. /w3tcompact/icons/smile.gif Now if only I can get my hands on some self healing seals I would be sitting pretty. ha,ha
Darin
   / L35 Tires #43
kubmech, on both the '95 B7100 I used to have, and on the '99 B2710 I now have, I have noticed occasionally when I start to move the front end loader very slowly, it will first move slightly in the opposite direction from what I wanted, then start the proper direction. I've found that occasionally my hydraulic top link does the same thing. That only seems to happen when that particular cylinder has not been moved in awhile. I've always assumed this is the same situation you're talking about, and that it's normal for these pieces of equipment.
Bird
   / L35 Tires #44
Yes Bird that is quite normal, especially with the FEL, those Husco valves are'nt the tightest in the world and the load checks will not seat immediately. Some are worse than others,but that's pretty much the nature of the beast.
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
