Tires L35 Tires
   / L35 Tires #31
Re: Front axle seals
Filled or weighted tires are putting strain on the front end? Would running with a full loader do the same thing? Should 4x be avoided?
SHF
PS Thanks for the tip.
   / L35 Tires #32
Well, if you don't need 4x4 don't use it. That will save wear and tear on the whole front drive system. As far as the full loader or weighted front end (suitcase weights) Sure that's a factor but that's what the front end is designed for, but hanging 50-75 lbs directly off of the axle is a whole other story.
   / L35 Tires #33
Is it possible for the front axles seals to stop leaking? I have been checking the seal situation out and it appears to have ceased. I know the first thing you will think is that the oil level is gone but I check that as well and it up to the hole. Is it possible that something could have jammed up in there because I cleaned the area good awhile back from dirt and such because I painted the area to make it look purty/w3tcompact/icons/smile.gif? Shoot if you say no then maybe it's becuase the darn thing needs to get dirty again and not look so dang shiny. /w3tcompact/icons/wink.gif
Curiously
Darin
   / L35 Tires #34
well, uhmm, hmmm, ah, ok, maybe you have those self healing seals/w3tcompact/icons/smile.gif Just keep an eye on it.......
   / L35 Tires #35
I like that---keep the area clean---. That is impossible for me to do I spend alot of time in the mud. Guess I could take a hose to her once in awhile for the heck of it./w3tcompact/icons/smile.gif
Gordon
   / L35 Tires #36
Thanks kubmech for the response. Here are the symptoms. When I push in the hazard light (center with triangle on it), both turn signals flash. If I also at the same time push the turn signal indiator in either direction, that side starts to flash and the other side stays solid (lighted but doesn't flahs).
But if the harzard switch is not engaged, if I use the turnsignal switch in either direction, that direction flashes and the other side comes on and stays solid!
Joe
   / L35 Tires #37
That's the way they're suppose to work, no worries/w3tcompact/icons/smile.gif
   / L35 Tires
In response to your Brake light question, if it hasnt been already answered, the L35 doesnt come with brake lights. Sorry if anyone has already proposed a solution to your question I just havent had enough time to read over all replies.
The Ben from MA /w3tcompact/icons/cool.gif
   / L35 Tires #39
Boy when a persons wrong we should admit it right?/w3tcompact/icons/smile.gif Anyway what I wanted to let you know, if you didn't already, that upon further looking into my front axles seal leaks I removed all the plugs (fill and check) and noticed none coming from the check one. Hmmmm there was a drop on the fill plug threads and thats all that I must have seen when checking it awhile back. Well I added oil to the front axle and hopefully nothing to bad happen. I haven't ran it in 4wd or actually in any drive to much lately so that is probably good. Anyway I have no self healing seals /w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif But most of you probably new that anyway. ha,ha.
Here is a question- when I was using the unit yesterday I was running the loader and noticed that when I placed the bucket edge on the pile the rods would compress back into the cylinder. HUH? When I moved the bucket in the opposite direction it would come back out and stay out. Also another strange thing happens too when using the backhoe there is a stall in teh hydraulics for a second and then it will work fine again. Any suggestions or thoughts? Thanks
Darin
   / L35 Tires #40
Thanks kubota-monkey that probably would be a heck of a job for the brake lights to be going on and off all the time/w3tcompact/icons/smile.gif I know what you mean about not having enought time to read through all of them. /w3tcompact/icons/wink.gif
Darin
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
Hose Reel (A55787)
Hose Reel (A55787)
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
