L35 Owners.....please help!
/ L35 Owners.....please help! #1
hutch4472
Central California Foothills
L35
I recently bought a 2000 L35 with 1300 hours. There is a grease zirk just behind the front axle pivot point under the tractor. What does this grease? After only 5-10 "pumps" from my grease gun all the other zirks ooze grease out from someplace. I have put two tubes of grease into the one behind the front axle and havent seen any sign of grease coming out ANYWHERE.
Ive put about 1 hour on the tractor since the last grease job which is when I put so much grease in that mystery zirk. Now today the hydraulics are acting up. It sounds strange (the hydraulic pump I guess) at high RPM and the hydraulics are suddenly very jerky. Like as if it is low on fluid or the pump has gone south. The fluid level looks fine on and the fluid color look good on the dip stick. When I pulled the filter however the fluid that comes out looks awfully dark. I didnt see any grease in it that I could tell but it doesnt look like nice clean hydraulic fluid should.
Did I push grease someplace it shouldnt be? I would think if I blew out a seal with my "over" grease job on that zirk that whatever fluid that seal was holding in would leak out. I dont see anything leaking anyplace.
Maybe some (or allot) of the grease got pushed into the hydraulic system but its keeping the fluid from leaking out?
Any help would be greatly appreciated. Thanks in advance. Hutch
/ L35 Owners.....please help! #2
There is not any grease in your hydraulics, all you did was grease the front axle pivot point like you should every 10 hours of operation....
Ok...I didnt think the two systems could be tied together anywhere but the coincidental hydraulic problems had me thinking too hard.....
My concern was that after two tubes of grease no grease came out anywhere. I bought the machine with 1300 hours and I have no idea what kinda routine maintenance it had. It came for a utility company in Cleveland Ohio. All the other zirks looked to have been greased regularly but who knows. Im sure enjoying the tractor but hopefully I can get this hydraulic issue figured out.......thanks for your reply.....Tom
/ L35 Owners.....please help! #4
No problema! :D
I doubt that you'll have to grease that particular zerk for awhile though after you put 16 ounces of grease through it! LOL :D
/ L35 Owners.....please help! #5
If all else fails, contact Kubota and purchase a shop manual.
Ya I bought the Kubota service manual. It was basically a $200 crappy photocopy of an original but thats another topic I guess.......the manual list the following possible causes for my problem:
-Low or incorrect hydraulic fluid
-Fluid filter clogged
-Loose or broken suction pipe
-Relief valve setting too low
-Hydraulic pump malfunction
So I am going to change the fluid and filter today and go from there. It really sounds and acts like the pump is starving for fluid but the level is fine.....so well see where this leads me.......thanks for the replies....much appreciated......Tom
Well unfortunatly I was right......I managed to push grease into my hydraulic system. When I pulled the plugs to change trans/hyd fluid one of them (the one nearest the overloaded zirk) had grease on it. Plus I can stick my pinky in there and it feels like Im sticking it in a tube of grease. So then I cut the filter in half and it was LOADED.
Now the tractor is working fine again but I will have to keep a filter handy for a long time now. I suppose it will take along while for all that grease to dissolve and be thinned out of the system but........I think the alternative of tearing the tractor down and mucking the grease out is alittle daunting.
/ L35 Owners.....please help! #8
Yikes, that sounds pretty unbelieveable that there are grease zerks in the hydraulic lines, there aren't any in my L-39's hydraulic system???????
/ L35 Owners.....please help! #9
Is this a picture of the grease nipple in question? These are the only ones that come close to the location. They are used to lube the steering cylinder bushings and shouldn't have any connection to the hydraulic system.
Can you post a picture of the location you greased? Just so I don't duplicate it...
jb
I will post a picture of it tomorrow if its still light out when I get home. It is not the one in that diagram. It is right behind the rear axle. I am thinking maybe the Utility company I bought it from added it for some reason? I cant think of why they would but.....I cant find any indication of it in the service manual nor from any other L35 owners here.
AAARRRRRRRGGGGGGGGHHHHHHHHH!!!!!!!!!!!!I cant believe I put over a tube of grease into my hydraulic system..........IDIOT!!!!!!
/ L35 Owners.....please help! #11
you said in your first post it was behind the front axle, now it the rear. sounds like we need the pic to sort it out.have been scratchin my head on this one and i still cant figure out why a zerk is any where near the hydraulics. somethings not right here...
/ L35 Owners.....please help! #12
Hutch, please do get some photos so we can figure this out. I just don’t see how a high pressure hydraulic system could be contaminated through a grease fitting. My old brain just can’t come up with a situation where hydraulic fluid and grease would be allowed to mix by design.
MarkV
Sorry been out of town, and now I am at work. I will go off shift Wed. morning and will post some pics. The Zirk is just behind the front axle and is pointing basically at the left front tire.
I dont understand this at all either. Seems like if I blew out a hydraulic seal with grease it would then leak hydraulic fluid. I'm guessin the grease is keeping it from leaking maybe? It is definately in the system though, just on the low pressure side. I am going through hydraulic filters quickly. One at one hour and another at about three hours so far (at about $30 bucks a pop). When I pulled all the (four) trans/hyd fluid drain plugs the one nearest the zirk had grease on it.
I hate to keep running the tractor with it in there but......to get to where the grease is at looks to be a MAJOR tear down. Any other sugessions?
Will post a pic soon as I can. Thanks for the replies so far. Hutch
/ L35 Owners.....please help! #14
When I came across this I could not help but see if such was possible.
After looking at the parts manual I will have to say yes that pumping enough grease into the fitting at the back side of the front axle on the L35 could find it's way into the transmission and thus into the hydraulic filters,etc.
The 4WD drive shaft is sealed so well I do believe that grease forced by pressure from a grease gun could travel up the metal covers and past the oil seal and enter into the transmission area.
The oil seal was to keep oil at no pressure in. Not to keep grease under pressure out.
Look at the picture and see if you agree.
Yes I THINK that is the grease zirk in question. Sorry I dont have a picture yet, I'm still at work (we work 3 consecutive 24's/week), I will post one as soon as I can take one and figure out how to post.
It is just behind the front axle and it LOOKS like it feeds that front driveshaft tube.
I think I was just being a frustrated ****** and I pumped that thing FULL of grease with a cordless grease gun (yes, the ones that pump at around 7500psi). So I wasnt able to FEEL the resistance increasing before it pushed past the seal. I was just frustrated and like an IDIOT I kept my "finger on the trigger" waiting to see where the grease was coming out. Which of course I couldnt see because it was coming out in my transmission case.
Sure appreciate the replies.........Hutch
Happy Thanksgiving all,
Here is a picture of the grease zirk behind the front axle on my L35 that I overgreased (ALLOT). I figure the grease traveled down the front driveline tube, through a low pressure oil seal (as was mentioned) and right into my hydraulic system. AAAAAARRRRRRRGGGGGGGHHHHHHHH!!!!!!!!!
Hutch
/ L35 Owners.....please help! #17
So how many squirts does the manual recomend there? If it is not specified how many do you think should go in?
Well.....I didnt see any mention of it in the manual....I guess I should check more carefully? It was just another grease zirk as far as I WAS concerned.......but I guess I THINK somewhere around 1-1/4 tubes LESS of grease should go in there?
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2022 EZ-GO ELITE...
