L35 or L4610???
/ L35 or L4610??? #21
Joe,
Nope,never did and couldn't imagine why you would want to unless you had a mid-mount-mower.I did a fair amount of brush and field mowing w/a brush hog and when I was mowing I would curl the bucket back all the way and lower the loader so the bucket was about 6 to 10 inches off the ground,this did two things,1-the bucket would hit an object(rocks or stumps) that was a potential hazard for the mower or machine,this way I could stop or adjust the height of the mower to avoid any damage and 2-it would give you a clean line of site.Also I wouldn't let the fact that the hydraulics for the hoe are "built in" it actually makes for a cleaner setup and better hoe performance.One more thing, as somebody else has allready said for the money it is worth looking at the L48,it isn't that much more than the 35 money wise,but it is quite a bit more machine,I've run one and like everybody seems to say,(and I would have to agree) it is very powerful and very smooooth!
/ L35 or L4610???
Thanks to everyone that answered questions and gave thoughts and experiences. After several people suggesting that I take a closer look at the L48, I've decided to to take a close look at it. While visiting the local dealer I asked for a quote on the L48 and he quoted me $39,210 after the $1500 rebate was subtracted. Seemed high to me, what do you think? I know there are some threads on the L48 vs. the L4610 so I'll be watching those closely also. Thanks again to all.
/ L35 or L4610??? #23
Joe,
That price sounds pretty good,especially considering an L35 goes for about 33-34000.Did you price the 48 with any options,and if so which ones?
/ L35 or L4610??? #24
I assume that was for the TLB version. If this <A target="_blank" HREF=http://carverequipment.com/L48_tractor_loader_backhoe.htm>http://carverequipment.com/L48_tractor_loader_backhoe.htm</A> is any indication, then that sounds like a good price. The guy I bought mine from said he paid $42,000 for a year ago.
-david
/ L35 or L4610??? #25
Joe,
The price sounds OK pending options & those can drive up the price. A good price for the L48 is around $38K, but check a few dealers first, seem the prices in west are higher for TLBs'
Since this is the Orange forum and you are looking at the L48 might want to take a look at the JD 110 as an option. I said look..
Carl
/ L35 or L4610???
Tags,
That price was the basic TLB with the HD loader bucket, 12" hoe bucket, rubber stabilizer pads, and a block heater.
Joe
/ L35 or L4610???
DavidinNH,
It was the same as in your link except it didn't have the 4n1 bucket. It just had the HD bucket.
Joe
/ L35 or L4610???
Carl,
It does seem that prices are a little higher in the west (at least in Colorado) from some of the postings I've seen. I've priced the L4610 and the JD4710 and they both seem to run about $1000 to $1500 higher here than those I see posted from the east coast.
I've considered the JD110 but it appears that there is a considerable wait and the dealer I spoke with knew nothing about it. I had much more info from reading on it here than he had.
Joe
/ L35 or L4610??? #29
Just out of curiosity, why did you select a 12" backhoe bucket?
When I was looking at new equipment, I was just getting around to thinking about bucket sizes. I then found the used L48 and it had a 2' bucket. I figured that I would start with that and could always buy a second, smaller bucket if I didn't like it. I've now used the backhoe for several projects - digging stumps (4" to 24"), removing rocks (around here, they always seem to be small and then when you start digging, they end up being 2-3') and digging ditches. I certainly haven't clocked a ton of backhoe time, but right now the 2' bucket seems to be about right.
I haven't come across any discussions on this topic, but I haven't gone looking either.
-david
/ L35 or L4610???
Hi David,
Two reasons for the 12" bucket: 1) I plan to dig for a septic system and wanted to keep the digging for leach lines narrow to disturb as little as possible. 2) I am in very rocky soil with some rocks up to 3' in diameter and read in another post that having a narrower bucket would put much less stress on the pins at attach it and do less damage if you hit a rock or stump with the edge of the bucket. My thinking was that if I needed to go wider I could always take a little more time and get there with a 12" but I couldn't go narrower with a 24". If I've really made a mistake on the narrow bucket I could later just bite the bullet and get a wider one.
Joe
/ L35 or L4610??? #31
Hi Joe - If I remember correctly, leaching line trenches are dug 24" wide. The eleven-foot-class backhoe on the L48 is well-matched to a 24" bucket - plenty of power. I have a very similar setup and I don't find it disturbs the nearby ground. The larger bucket is also quite nice for getting out the occasional grain-bag-size rock.
/ L35 or L4610???
rbargeron,
Thanks for the info. I hadn't even checked it out, I just figured that 12" would work best. You may have saved me the extra cost of 12" bucket. Now if I could just make up my mind on the tractor.
/ L35 or L4610??? #33
I agree, the machine seems to be very well matched to the 24" bucket. I was expecting it to be too big, but it seems just right. It seems that most of my rocks are grain-bag sized or larger and it plucks them out very nicely.
-david
/ L35 or L4610??? #34
Joe,
To just dig all the time w/the 12" bucket on that hoe will make you mental,not to mention that wet material or clay will pack into that bucket to the point you'll have to constantly "bang' the bucket against the stops to dislodge the material,th 2 footer is the way to go.I believe Werk-Brau offers a pretty slick quick coupler for the hoe,that would give you the ability to switch buckets in a snap,the best part is you could start w/one bucket and as you get some duckets saved you could buy another,all though it is allways nice to put all the goods into one finance package,besides,whats a few thousand dollars to a bunch O' rich guys like us??/w3tcompact/icons/smile.gif
/ L35 or L4610??? #35
It's what powers a Boomer (yuk, yuk, yuk)
/ L35 or L4610???
Hi Tags,
I appreciate your comments on the bucket width. I'll move up in size. If I want to get multiple buckets, are the connections universal so that I can just shop for any used buckets, or do I need to worry about getting kubota brand?
BTW, have you got the 110 yet?
/ L35 or L4610??? #37
Hi again joe - it has been good to read about your fact gathering process on this - I think your decision is well-informed and you will be very happy with the L4610. Your original post said you were looking for a good general-purpose machine and you've homed in on a beauty. I was going to suggest a Bradco but I held back because I have one and I'm always bragging about their quality and design - people could be getting tired of hearing it. On the subject of backhoe bucket width, your soil conditions may be important - if you have clay or heavy/wet conditions, the wider buckets don't get plugged as often. Good luck and, whatever you do, have fun. /w3tcompact/icons/smile.gif
/ L35 or L4610??? #38
Joe,
I believe that Werk-Brau and or Wain-Roy(woods equipment)both make couplers and buckets for the 48.What you would do is tell your dealer you are interested in a coupler and bucket(s) for the hoe,he would then subtract the price of the Kubota bucket from your price and add the price of the coupler and bucket(s).Depending which coupler you go with WB or WR you would stick w/that companies buckets,I have WR coupler and buckets on my excavator and have been very happy with em'.Ahhhhh yes my 110.......no I haven't gotten it yet,but I've been told I'll have it the week of the 13th but I'm not gonna hold my breath but I will keep my fingers crossed/w3tcompact/icons/wink.gifthanks for askin',let us know how you make out ,at this rate you'll have an L48 before I have my 110!!
/ L35 or L4610???
Hi Tags,
As I've done so many times in the past as I've been learning about all the features and pros and cons, I've changed my mind. I'm now getting an L4610 with FEL and a bradco 509 backhoe. It is not as heavy-weight as the L48 but I think it will fit my general purpose needs better because I am concerned that I may need to maneuver into some tight places where I might need to take the FEL off, and it definitely fits my budget better. I got what I think is a very good deal. I posted under a new subject of L4610 pricing. Here is the post:
After much investigation, studying, reading, changing my mind, and a lot of fun just dreaming, I THINK I've finally made up my mind that I'm going with an L4610 and bradco backhoe instead of the L35 or L48. It seems to fit in between the two for general purpose use and fits my budget. So here's what I'm looking at currently:
L4610 HST
LA 852 FEL
66" bucket
R4 tires
200 lb weights for rear
Extra hydraulic remote for front loader
Bradco 509 backhoe installed
16" hoe bucket
Delivered
All priced at $31,500 plus tax. The dealer has sharpened his pencil twice on the bid and I think this is his final one. I think for this area, this looks like a very good bid.
I'm also discussing exchanging the 66" loader bucket and getting a skid steer quick tach mount and an ATI GBC-66 Grapple bucket. For the quick tach mount and a demo grapple bucket it will run about an extra $2100.
Anyone else have any thoughts or comments on the configuration or price?
Joe
/ L35 or L4610??? #40
Joe,
That sounds like a good deal,as I said before the most important thing is to have a machine that fits your needs the best and the 4610 does that,thats what matters most in the end.The ATI qt is a great option I had one on the 35,it allows so many more attachment options,you also may want to look into adding the rear hydraulics for the top n tilt also.Well keep us updated................it sounds like someone is getting a new toy.....uh,oh,I mean valuable workpiece to accomplish jobs around the house. /w3tcompact/icons/wink.gif
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
