L35 or L4610???
   / L35 or L4610??? #1
jedens
Bronze Member
La Veta, CO
Kubota 4610
I've been comparing tractors for quite a while. I'm looking for a good all-around utility tractor to clear dead and live trees, pull/dig stumps, mow, do general landscaping, put in a long driveway, clear snow, etc. on 35 acres that are at 7400 ft elevation in Colorado. I definitely want to get a FEL and backhoe from the start. I've looked at the JD 4710 with the 460 FEL and the 48 backhoe but I don't like the way the backhoe hydraulics work because they flow through the tractor instead of being self contained. I've looked at the L4610 and it appears to be comparable in price and has a little better specs on the FEL. I've looked at the L48 but it looks like too much tractor and would be less maneuverable and more expensive. I've also looked at the L35 and while it is rated quite a bit lower on gross HP and PTO HP than the L4610, the FEL specs look almost as good and the backhoe looks better than the L4560 backhoe for the L4610. The L35 with FEL and backhoe also appears to be a little less expensive than an L4610 with an LA852 FEL and L4560 backhoe. The only drawback seems to be that the PTO HP on the L35 is 26 HP as compared to 40.5 on the L4610. How big of an issue is that if what I'm going to use the PTO for is mainly mowing, tilling, post hole digging, and box blading? Any thoughts on the pros and cons of getting an L4610 over an L35 or vice versa would be appreciated.
   / L35 or L4610??? #2
Jedens, if a lot of backhoe is a must, the L35 can't be beat. (except by the L48 which I have) If a backhoe and a lot of loader work is needed, the L4610 HST would be perfect. (as would the L48 since it to is also HST). If you know what you want to run PTO wise, check the implement requirements, that will tell you a lot. You will find many things will run with 26 PTO hp just fine. Rat...
   / L35 or L4610??? #3
Joe, I'd like to re-emphasize what you may know: as Rat points out, the L35 is not hydro. For the jobs you mention other than the backhoeing, most people much prefer hydro.
Another consideration: mowing, tilling, post hole digging, and boxblading will all require you to remove the hoe and use the 3ph. I am not familiar with TLB's (the L35 and L48), so I don't know how conveniently you can get the hoe on and off. As between the JD hoe and the hoes you might put on a 4610 (Bradco, Kubota or Woods), I believe JD has far and away the fastest connection system.
The issue of self-contained hydraulics vs. sharing the tractor hydraulics has been discussed and debated here many times. You can use the search function. There are supposed pluses and minuses both ways. My personal conclusion is that if the tractor has sufficient hydraulic flow to drive the hoe, that is the simpler, more efficient and cheaper alternative.
   / L35 or L4610???
Thanks Rat and Glennmac for the quick responses. I've been looking at some of the previous posts about GST vs. HST and it does appear that the HST would be nice. I wonder why both the L21 and the L48 have HST but the L35 doesn't??
   / L35 or L4610??? #5
Jedens,
I owned an L35 and I have to say it is a machine that just won't quit!I'm not real familliar w/the 4610 but from reading posts on this site guys love em',as far as removing and installing the hoe,it's a snap and it takes longer to install the three point hitch arms than it does to remove the hoe.The big advantage to the B21,L35,and L48 is that the loader and hoe are integrated into the machines frame work,which ends up being a little more bulletproof compared to adding a loader or hoe as an "afterthought".I also used most of those implements you said you would use and never had a problem of not enough power,if you are going to do serious loader and hoe work I would go with the L35,the best thing to do would be to try to rent a 4610w/loader&hoe then rent an L35 and see which one fits you and your needs better.
   / L35 or L4610??? #6
Joe,
I see you already have a AC so if you keep this for the 3PTH type tasks - box blade and grading, then there are fewer changes of the BH. Changing the BH on the L35 is easy - takes a few minutes once you get the hang of it. Attaching the 3 PTH arms takes longer.
In either case the L4610 with BH and subframe will still require removal and install of 3PTH arms, and I don't beleive the RR of the BH is as easy on this setup. In addition, you have a sep seat on the BH and the overall length tend to be a bit longer than the L35 combination unit. This is imp if you are traversing tight areas etc.
Regarding the HST vs GST only on the L35, I have no good explanation, however, Kubota sticks with what works in the industrial arena, and the GST works well. The other comments re: using the HST is easier, as I can move the unit when digging/trenching w/o changing the seat position, just raise the stabilzers, reach around and push the fwd/rev foot pedal. I think the L35 can do this but not sure.
Since you have rocks and tree stumps, check out the Grd clearance with the subframe vs the std grd clearance on the L35. This is imp when doing rock work, navigating stumpy areas, also look at the under side protection offered by both against stuff getting jammed into the bottom side - can make a mess quickly.
Regading mowers you have only a RMM option on both units since the subframe prevents a MMM on the 4610 from what I recall.
If you can get a ride on each one, setup the way you want that's probably the best test.
Carl
   / L35 or L4610??? #7
Hi Joe - you've definitely been doing your homework. The L35 and L4610 are both great machines - but are quite different. How much of your land is open now? If you're mowing more than 1 or 2 acres, it's nice to have a removeable FEL . But if most of the land is undeveloped the all-around ruggedness of the L35 might serve you better.
For doing major earthwork - putting in roads, taking out stumps and rocks, preparing building sites, etc. - power, weight and strength rule. There's truth in the saying that, except on a developed site, there's no such thing as too much tractor.
Owning an L48 for a few years might make economic sense. Then, when all the serious earthwork is under control, maybe switch to something smaller. Except for having your money tied up, the unrecoverable cost of ownership of any Kubota model is very low.
The great part is - whichever way you go will be good ! /w3tcompact/icons/smile.gif
   / L35 or L4610??? #8
Keep in mind that the L35 and L48 both use the tractor hydraulics to power the BH, just like the JD, If that's a reason to reject the JD, wouldn't is also be cause to reject the L35 and L48?
Personally, I woudl reject the L35 because it doesn't have HST, and ignore how the BH is powered. I think you will find they all work just fine.
   / L35 or L4610???
Tags,
Thanks for the info. It sounds like the L35 has been a good machine for you. Did you ever wish you could remove the FEL?
Joe
   / L35 or L4610???
Hi Carl,
Your point about ground clearance is a great one that I hadn't thought of. It looks like the L4610 has a couple of inches more ground clearance than the L35. I suppose I could increase it on either machine with larger tires. Thanks again for the info!
Joe
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
