L35 Action Shots
/ L35 Action Shots #1
bandit67
Veteran Member
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
OK, so while I wait to unload some real estate in this scorching hot market :rolleyes: so I can buy a new machine, I have to settle for occasionally renting a machine to slowly chip away at some of the work I want to do around the new-to-us property.
This is an L35 I've rented a couple of times - when I finish the job I actually rent it for, I spend the remainder of the day chipping away at a bank in front of the garage that needs to come out so we actually have enough room to get the vehicles in and out a little easier. It takes a while digging with the 12" bucket, but there's a mix of sandy dirt and decomposed granite, so the smaller bucket is necessary to deal with the rock. I have a full size New Holland TLB reserved for Labor Day weekend to hopefully finish the job. Before that, I've got some fellas coming out to take down 3 trees that are up on the bank that I don't want to deal with because of their proximity to the house.
So here are some shots of the dig out in front of the garage:
/ L35 Action Shots #2
Re: pic 5. Why dont you just cut into the bank from the bottom using the loader? It looks a little scary perched up there.
/ L35 Action Shots #3
My thoughts exactly... I don't have that much faith in dirt.
/ L35 Action Shots
Because around what appears to be the nice loose sandy stuff are veins and chunks of decomposed granite. Without a toothbar, the loader is pretty worthless, so I have to break things up with the backhoe, then come in from below and pick up the spoils with the loader.
It's pretty solid as far as footing because of all the rock. Not sure if any of the pics I posted showed it, but one of them shows me looking down at the stabilizers while digging to be sure the bank wasn't moving or breaking away. I've done it twice now, and no breakaways or close calls. The bank doesn't even break away in the rain - we had major downpours every afternoon for 3 weeks straight, and the hillside didn't budge.
The very first time I was up there, I was a bit nervous, but after working up there for a while, I got a bit more comfortable. Plus, I always had my seatbelt on, just in case.
To show the stability of the ground, to the immediate right of the pics is a 24" diameter Ponderosa Pine (can't see it in any of the pics) that's barely 2' away from the cut that the builder made, and the remains of a 6" diameter tap root that they cut through 5 years ago. The tree hasn't budged since the house was built. That's one of the trees that is coming out, because I figure it's just a matter of time before it decides to come down. It's kind of a shame, though - it's survived a major tap root being removed, and a lightning strike 15-20 years ago - it's been quite the trooper.
/ L35 Action Shots #5
I do this type digging a lot, and prefer to use the hoe from down on the level. Loosen up what you can, than turn around and use the FEL to move,,
/ L35 Action Shots #6
Naturally there's things you can see and feel that we can't just looking at pictures. Sounds like you're being careful, just watch you don't develop a false sense of security.
Also a good suggestion. That's actually how I plan on digging out most of the basement for our new addition, since the one side will be walkout level, so easy-access.
/ L35 Action Shots #7
We spend some time in Colorado and I can testify that the dirt there is about 25% dirt and 75% rocks.
The ground he is on is a lot stronger than it looks in the pictures.
BTW, a beautiful place you have there. I looked it up on the map and that area is really beautiful. We will (hopefully) spend 2 weeks in Buena Vista in September.
Bill Tolle
/ L35 Action Shots
Well I went back and looked at the pics since everyone was commenting on how the machine actually stayed up on the hill without the hill collapsing. Guess it does look quite a bit more precarious from the pics taken from that angle. :cool: It wasn't anywhere near as bad as it looks from the pics.
I've survived so far by letting my knees tell me if I should be somewhere - if I'm somewhere I probably shouldn't be, I get a tingle in my knees that doesn't stop until I'm anchored or back to a safer spot. I get it when I'm up on roofs a lot - it's the kind of feeling that doesn't go away, so it keeps the rest of my senses on high alert. ;) Heck, I even get the tingle when I see my kids out or up on something that they could fall from. :eek:
There was no 'knee tingle' while I was up there working, and there was no ground movement until the backhoe dug in and made something move. If there were either of those 2 scenarios, I wouldn't have been working from up there. I'm also pretty good at picturing in my mind what could happen if I'm not careful, which has kept me pretty safe and fairly injury free over the years of hiking, mountain biking, trail riding, street motorcycles, etc.
Great, now I probably just jinxed myself after talking about it. :eek: Better be on alert for the next few days. :D
/ L35 Action Shots #9
I will take your word for it that the soil is stable enough to support the tractor on top without issue, but given that I have known plumbers who have worked in un-shored trenches for 30 years or more just to be crushed by a freak cave in ... I would opt instead to work from the bottom reaching up.
I would think that it would be easier to pull the stuff down than dig it up anyways. Does the BH reach high enough from the bottom?
/ L35 Action Shots
Wow, guess that's the last time I'm going to post pics - too bad 'cause in a couple of weeks when I rent a full size machine to take out the rest of the hill that needs to go, there should be some neat pics of that.
I dug a little from above, I dug a lot from below, I dug a little from the side. The only pics I had were some from the dig from the top that I thought looked kind of cool, but the safety police that weren't there and didn't see the excavation, the surrounding land outlay, etc. can't give it a rest. :rolleyes: It was actually a bit difficult digging from above because I was far enough away from the edge of the bank that it was affecting the reach of the backhoe.
Whatever you guys do, don't go to the thread that has the cool videos of wheelying backhoes, excavators getting off flatbed trucks with no ramps, backhoes climbing up and perched on top of railroad cars, and 3 year olds running mini-excavators. :eek:
/ L35 Action Shots #11
bandit67 said:
Wow, guess that's the last time I'm going to post pics ... the safety police
I'm probably really stepping in it here but I just don't understand this reaction. I've seen it a few other times as well (ROPS maybe?) bandit67, none of these comments has been derogatory or insulting towards you. Folks are only concerned for your safety based on what they see from your photos, which frankly do look a little frightening. You can choose to accept the warnings or not, but I don't think complaining about 'safety police' is necessary.
flames > /dev/null
Be safe.
-Brian
/ L35 Action Shots #12
bandit67,
I really appreciate your posting these pictures.
As a new TLB owner I've enjoyed reading the debate about the safest and most efficient way to handle an excavation like this. Your pictures have made me think --- which usually is a good thing :)
Hopefully the discussion will continue -- I have a lot to learn.
Talon Dancer
/ L35 Action Shots
n8wrl said:
I just don't understand this reaction. Folks are only concerned for your safety based on what they see from your photos, which frankly do look a little frightening. You can choose to accept the warnings or not.
I admitted that the angle of the pics makes it look much worse than it actually was. When I got home tonight I stood out there looking at the 4' high bank, and casually mentioned to my wife about all the safety related comments after I posted the pics. She chuckled, saying "that little bank"? "You were so far back, plus look at the slope of the edge of the bank. That tractor wasn't going anywhere. Like anyone should be advising YOU about being safety conscious."
I do appreciate warnings and concerns for my safety, and have read plenty on TBN to keep me aware enough to stay out of trouble when using tractors. But the repeated disregard to my responses trying to clarify that it really wasn't as dangerous as the pics seem to show got a bit old. Goes to show you how pictures can be worth 1000 words - it apparently will take that many words from me to convince folks that it looks much different in person.
You can choose to accept my attempts at explaining that it looks much worse than it actually is, or not.
/ L35 Action Shots #14
n8wrl said:
...Folks are only concerned for your safety based on what they see from your photos, which frankly do look a little frightening. You can choose to accept the warnings or not, but I don't think complaining about 'safety police' is necessary...
I agree. I made a note to self not to be concerned ever again with bandit67's personal safety (complete stranger after all, why should I care). I suppose one day his sudden disappearance from TBN could be fodder for all sorts of speculation as to which activity was to blame the day the knees were slow to tingle. Pride goeth before a fall.
/ L35 Action Shots #15
bandit67 said:
I When I got home tonight I stood out there looking at the 4' high bank, and casually mentioned to my wife about all the safety related comments after I posted the pics. She chuckled, saying "that little bank"? .
Bandit. I dont consider myself one of the safety police. I dont even have ROPS and I've never posted anything about safety. All I did in my previous message in this thread was to ask why you were doing it from 'up there' because (in the pictures) it looked a little scary. But I read your response and figured you know what you're doing.
BUT now that you're implying that "that little 4' high bank" is nothing to worry about... well......
/ L35 Action Shots #16
Spider Senses RULE!! THEY RULE!! ;)
/ L35 Action Shots #17
Greetings,
Find yourself here:
Flame Warriors Home
Strangely enough, Safety **** is NOT listed.....
To quote Egg Shin from Big Trouble in Little China: Life is like a buffet, you can take what you want and leave what you don't....
Everybody has their reasons for posting....or not.
Enjoy!
/ L35 Action Shots #18
Bandit,
I missed the pictures of your death-defying-tractor-tightrope-walk..............
Please put them back.....................please!
/ L35 Action Shots #19
Renob said:
Bandit,
This verifies that I'm not blind afterall.
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2018 Kawasaki 4x4 Diesel Utility Cart (A66734)
2018 Kawasaki 4x4...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
CAT 613B Transmission (A68134)
CAT 613B...
THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
THE MACHINE CO...
