Buying Advice L35 3pt arms solution
/ L35 3pt arms solution #1
Ludscapes
East Liverpool, Ohio
Kubota L35
I am new to the Kubota World. I was a new holland owner for years and just recently bought an L35 TLB 1300 hrs non rental. I found out that the 3pt arms are not with this machine. I called the original owner and he said he didn't get them when purchased so it looks like I am going to have to purchase these either new/used since I plan on tilling, using other 3 pt attachments here in the spring. I have read all the posts on here prior to posting this but I haven't seen any straight forward answers as to where to find them cheaper than the $1,000 price for new from a Kubota Dealer. Can the L39 arms be used? Or other models? Can I get them any cheaper aftermarket? I really just didn't want to spend 1k. Any input would be greatly appreciated.
/ L35 3pt arms solution #2
Are you 100% sure they are not stored on the subframe? Just curious if the original owner you spoke with knew where they come stored on the tractor from the factory. Doesn't cost anything to just double check. Good luck.
Yeah I checked and they aren't there unfortunately, so I will need to purchase them from somewhere, "whoever you guys recommend". I am also looking to change the front loader over to quick attach here this month. Any particular company I should go to for the best quality and functionality so I can swap out buckets quickly to pallets or a larger mulch bucket. Thanks for the idea.
/ L35 3pt arms solution #5
that attachment looks pretty crude for the price. ATI makes a nicer one, and I'd expect it to be marginly cheaper as well.
/ L35 3pt arms solution #6
The L39 kit is what you want. Couple of extra brackets and some of the pins are longer than needed but the arms and top link are what you need.
/ L35 3pt arms solution #7
Today there are 2 different postings on the Seattle craigslist for kubota 3 point hitch arms. They don't say which model, but you might check it out and see if they'll ship.
Wow. After spending the whole day Sunday going over the tractor and cleaning it up I have came to the conclusion I got a good buy and it's built like a tank. Compared to my old TC 24D New Holland this thing is a serious price of equipment. The New Holland felt like a child toy. I am looking Into all of the above sites and companies you guys haves recommended for the quick attach and a local shop claims he can fabricate the entire system so I am also considering that option. Thanks for the recommendations.
I wasn't sure the L39 3 point arms were compatible but if they are I bet your right it will be easier to locate since its newer and more readily available. I just thought the 3 point arms would have been made by some aftermarket for 3-400 bucks but I guess not.
I'll log some more hours but I am loving the new to me L35 Kubota Tractor so far. I can see what the other users were talking about when they said "well Built". There is no way another 35 hp tractor could compare in build quality Glide shift is easy and it's a stout good feeling tractor. Only other issue is I am also getting 2 new tires for her this week. They are worn out and I'm sticking with the r4 industrial tread. Should I get 6 or 8 ply? Does it matter? Name brand?
/ L35 3pt arms solution #9
IIRC, a couple of years ago the L35's were about 1,000 and the L39's were more like 300. That was the reason to get the L39 set.
CHROME HUB CAPS FOR SEMI TRUCK (A64276)
CHROME HUB CAPS...
Tennant M30 (A64127)
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
