L3430HST steering problem?
/ L3430HST steering problem? #1
Vince
NE Pennsylvania
Kubota L3430HSTC/Ags./turfs - Ford 8N - JD 445 - JD 316
My L3430HSTC / LA723FEL steering stutters, jerks, does not turn smoothly under weight of bucket full with wet modified (stone & dirt). All is well with 2/3's or less bucket material. Problem occurs as tractor is near stopped, loader stopped and wheels need to go from lock left to lock right or vice-versa...same in forward or reverse....turf tires @ 3o psi. on front. Fluid level OK...110 hours on tractor...operating @ 2700 RPM...no other problems. Anyone else experience this? Any thoughts, suggestions about this? Thanks.
/ L3430HST steering problem? #2
Hi Vince…
You are asking the steering to do TOO much…. The weight along with wide footprint ‘turf’ tires, and not moving. Things are just stuck in place /forums/images/graemlins/blush.gif.
I have oversize turf on front and rear of my L4200… If I have a heavy load I make sure I am rolling BEFORE I try to turn. Just takes a little fore thought. KennyV.
/ L3430HST steering problem? #3
The big ag tractor we use when it has a full bucket can't turn lock to lock when stationary and the loader raised. It just makes the relief valve operate. Just rolling a bit makes it fine or having something heavy on the 3 point hitch works too.
(2) Corral Panels (A66408)
(2) Corral Panels...
LandPride Snow Plow (A62613)
LandPride Snow...
PALLET OF 1 5/8 HYDRAULIC HOSES (A65643)
PALLET OF 1 5/8...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
