L3430 PTO
/ L3430 PTO #1
mcnitt
Nevada City, California
Kubota GL3430
I am restoring a 3PH cement mixer to use mounted to my L3430. How do I keep the tractor from shutting down when I get up from the seat when the PTO is engaged? I am sure it must shut down as a safety procedure, but I don't think there is too much threat from a cement mixer, and I need to be on the ground feeding it.
Thanks,
/ L3430 PTO #2
You tilt the seat foward. There is another saftey switch that makes contact.
/ L3430 PTO
Thank You , Barnboy. It's so simple, I never would have figured it out!
/ L3430 PTO #4
You must first raise the seat forward......and then start your PTO.
2021 JCB 35Z-1 Mini Excavator (A64553)
2021 JCB 35Z-1...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2014 MACK CXU613 SLEEPER (A65643)
2014 MACK CXU613...
18ft Suzuki Lighted Sign (A65579)
18ft Suzuki...
