L3430 delivery this Friday
/ L3430 delivery this Friday
Thanks for the pics, 3050. It looks just like mine, only a little bigger. The cab is great, just like you said. It is quite a bit quieter with the cab and the visibility is excellent. It was a little hot over the weekend so I tried the AC out and it works real well. How did you break yours in? I remember seeing a post about break in a few months ago but was wondering what your method is. I have been using different speeds, throttle settings ( but not full throttle) and varying between L, M and H on the gear settings. I already have about 8 hours on it. Hope to get some pictures up soon.
Haz
/ L3430 delivery this Friday #22
The 5030 has enough power that I don't run it at 540 indicated PTO rpm except when I had the rear mount blower on it this winter. When I use the loader for moving round bales, it is just above an idle so most of the time, I vary the engine speed accordingly. One thing I do is I allow the motor to warm up before moving the unit and when I shut it down, I allow it to idle for a few minutes. We have a blanket maintenance program on the farm that works for all power units as well as the Kubota. I adhered to the 50 hour change for oil and all filters including hydraulic high and low pressure. However, I did not change the UDT at 50 hours. I added make-up UDT to the full mark on the stick to make up for lost fluid during the filter changes. The low pressure filter when removed, will allow UDT fluid to come out until you put a new filter on so you need to have one ready(The hydraulic filters are changed more often than the fluid even in Kubota's recommended maintenance schedule). I will change the UDT at 200 hours as I have with all my previous Kubota's. At the 50 hour interval, I replaced the front axle fluid (UDT) with 85-140 Shell Spirax GL5 gear oil. We are coming upon our hay making season and field work with this tractor requires 4WD mode constantly. I need the shock load characteristics of the 85-140 versus the lighter UDT. At the end of the harvest season, I will change the UDT, filters, engine oil and drain the front axle case and replace the 85-140 with UDT for cold weather use. I use Delvac 1200 super in the crankcase, but that's my preference. We buy 55 gallon drums of it and use it in all of our tractors. Any oil that carries the API certification that Kubota states in your manual will do. I would not recommend a synthetic oil. Petroleum based oils, changed frequently will be more cost effective in the long run. As long as you use an oil with the proper API certification, you will get the proper additive package that the engine needs. The main reason I didn't change out the UDT is that the tractor is hooked to a number of different implements, all with hydraulic cylinders that are used by our other tractors. Throughout the growing season, the UDT will become somewhat contaminated so in the fall I will change out the fluid. I just posted a couple of pictures of a GREEN tractor that was ours under the caption of "John Deere Supersteer". Take a look, it really trashed. if the operator did that to my new Kubota, I'd have kicked his rear end.
Daryl
Forage Services, L.P.
Hey 5030,
I didn't even notice you changed your name. Thanks for the info. I kinda got used to you being 3050. It had a nice ring to it. /forums/images/graemlins/smile.gif
Haz
/ L3430 delivery this Friday #24
Haz:
Let see, I changed my name 'cause RaT kept riding me about it so now it matches the tractor (Kubota) not (Deere), added a picture of my chubby self and put in a signature which has caused all my previous posts to have double signatures. I'm not very computer literate but I'm learning.
On the subject of your new Kubota and my now somewhat used Kubota, I can directly compare the tractors to Deere & Company products as we own Deeres also. Without deliberately raising the hackels of Deere fans out there, it's my personal opinion that the Kubota is a better constructed peice of equipment and a much better initial price and from my experience with Kubota's, they have all been mostly trouble free as far as breakdowns are concerned. I'm not stating that Deere is a second rate tractor, what I am stating is that Kubota is on par with the leader in the field and the initial cost is more economical to boot. A prime consideration in these recessionary times.
New/Unused ATS Mini Excavator (A65583)
New/Unused ATS...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
VERMEER FT100 MULCHER (A64277)
VERMEER FT100...
