Buying Advice L3400W/FEL OR MAHIHDRA 3535/4035 W/FEL
   / L3400W/FEL OR MAHIHDRA 3535/4035 W/FEL #1
welder57
Kubota L2500
I need some advice on which one of these tractors is the best buy(cost and upkeep required) and what a dealer will allow on my 2(wd) L2500 1998 model.
I sent a e-mail to two dealers here in central Alabama-did not get a reply-i guess they made enough this year in sells!!! I want to get the best deal, without getting taken. Thanks
   / L3400W/FEL OR MAHIHDRA 3535/4035 W/FEL #2
Firstly, you might want to consider the L3700SU as well, just like the L3400 but 1 or 2 more HP and the same price or cheaper. I don't think there is much of a comparison between the quality and tech level of the Kubota compared to the Mahindra. I suppose the Mahindra is cheaper to buy, I suspect over the years the Kubota will be less expensive to maintain and will have a much higher resale value.
   / L3400W/FEL OR MAHIHDRA 3535/4035 W/FEL #3
I need some advice on which one of these tractors is the best buy...
Make sure you test drive both tractors... in particular you'll want to mount a box blade on the 3ph of the L3400 (or the suggested L3700) to see if you can live with the "jerky" 3ph that some people are complaining is back...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
