Comparison L3400HST Versus JD 3320 - help!!
   / L3400HST Versus JD 3320 - help!! #1
Biocom
Hammond Ranch, Ca.
2011 Kubota L3400
New to the forum - sorry if this is a repeat - I have been shopping for a tractor and have ruled out the Sub compacts like the B3200 Kobuta and the JD 2720 - So I am raising the bar and have two dealers quoting and L3400 versus JD3320 -
I think both tractors are built well enough for my uses, but the primary use will be snow blowing a 1/2" mile gravel road that is on a hill.
JD 3320 has a 59" blower front blower and the Kubota dealer is quoting me a Erskine 60" rear PTO powered front snow blower.
Any and all opinions, "what I would do" (forget the rear snow blower:confused2:) are welcome.
Both are getting real aggresive on the pricing and finance terms :thumbsup:-
   / L3400HST Versus JD 3320 - help!! #2
What I would do (assuming money isn't a barrier) is buy the 3320 with the front blower, heated cab, 3pt back blade (for ballast weight and snow pushing), and also a good set of chains for all 4 wheels to get you up the hill when it turns to ice. With 1/2 mile of lane to clear, you are going to need a serious snow machine.
   / L3400HST Versus JD 3320 - help!! #3
1/2 Mile Road + Snow = Cab + Front Blower
   / L3400HST Versus JD 3320 - help!! #4
1/2 mile driveway is a long one on a cold day and there's a lot of snow to blow. It can be done without a cab but you are going to have to be wrapped up and lenjoy blowing snow. I don't know where you are located so cannot even guess how often you would be doing this or how much snow you get. I used to have a 1/4 mile drive and did it without a cab, never had a problem and I like to be outside so the cold never got to me and I live in a fairly heavy snow area. If you are in a heavy snow region, I would consider a cab IF that's your primary task with that long of a driveway. It's a lot of extra money but may be worth it.
   / L3400HST Versus JD 3320 - help!! #5
Those are pretty costly snow blowers. Maybe a (used) 4WD pickup and a Myers plow?
   / L3400HST Versus JD 3320 - help!! #6
I think you need to compare the L3240 Kubota to the JD 3320.
1.JD with cab only avaible with front snow blower
2.L3400 not available with cab or sub-frame for front blower
3.Erskine is top on the line rear blower(very pricey +$6,000 or so)
4.L3240 can be had with cab and sub-frame for front blower
Big debate over front or rear blowers and cab or not;your choice.I would not want to run a blower with-out a cab myself.I use a cab and a front plow.
Do a build your own on the Kubota and Deere sites...hopefully less 15% then compare.
   / L3400HST Versus JD 3320 - help!! #7
Where are you located and how much snowfall do you get???
Because unless you get several feet of snow at a time, a truck and plow is going to be WAY quicker. And a decient used setup will cost less than what just the blower add-on will cost you. So you can still buy a tractor if you have other tasks to do with it, just without the blower.
If the blower is a must for where you live, I would agree that you sould get a cab.:thumbsup:
   / L3400HST Versus JD 3320 - help!! #8
Out of the two tractors mentioned, I think the 3320 would be your best bet...:thumbsup:
Thanks All - Live at the base of Mt Shasta in Northern California - I have a 1978 Dodge Power wagon with a 440 and 7' Meyers- chains on all four wheels - four wheel lock low -
The problem is that there is no where to but the snow after plowing for a couple of weeks - Road looks like a bobsled run - Been fighting it for about 4 years - Son got stuck for 7.5 hours this year on the road waiting for a tractor to come dig it out - So I'm buying a tractor and just blow the snow off the road to start.
JD 3320 59" snow blower - anybody know if this blower has a lift kit?
   / L3400HST Versus JD 3320 - help!! #10
your going to want to look at a few prices on these before going further. The deere config is more tractor, however its probably going to be 7-8k more expensive than an L3400 w/ 3pt blower. Backing up for a half mile will be a literal pain in the neck. You probably need a setup more like is being quoted on the Deere. The 3320 falls between most Kubota models. There is not a good apples to apples comparison. The L3240 is a bit larger tractor, but really better suited to what your doing.
Mower King Brush Cutter (A53317)
Mower King Brush...
2015 VOLVO VNL760 SLEEPER (A57880)
2015 VOLVO VNL760...
2019 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
