Price Check L3400HST Price / Usage / Sanity check
   / L3400HST Price / Usage / Sanity check #52
Just a friendly heads up you should not post links to e-bay, craigs list etc.. Dont ask me how I know :eek:
Chuck K. said:
Congrats!!! Post some pics when you can.. They only look that good for a while
I have to wait 5 more days... Its killing me :eek:
I had to wait an extra 2 days for mine ... the wait was so bad I was DREAMING about having a tractor delivered (except in the dream it was the size of a tricycle with a finger-actuated FEL that was maybe a 1/2 cup in size).
I've only run it for a couple hours (mostly mowing) and I've already dusted it up pretty good as well as left some good orange paint from the FEL on a number of rocks hidden in the underbrush as I was feeling my way through.
Initial thoughts ... love the size/power, love the HST, love the 4wd, not 100% sure yet about the 3pt positioning (the brush cutter seems to not raise until I hit about a 6 out of 8 on the position control lever).
I need to try out the box blade soon, but I'm scared to death that I'll manage to mess something up taking off the brush cutter (I guess I will graduate to the owning/operating forum and try to figure all that out).
My wife and 10 year old daughter took a few "action shots" (wife in the "field", daughter from the house - everyone was safe). I'll try to post them below ... at least I think I attached them properly ...
   / L3400HST Price / Usage / Sanity check #54
Fuuny, I didn't know they started making the L3400's with shuttle shift as the ebay auction listed. Bet the buyer might be a little disappointed.
Nice pics of the L3400 being delivered, rare to see pics of one with R4 tires. Guess it's the first I have ever seen!
   / L3400HST Price / Usage / Sanity check #55
Go ahead and get one of the quick hitches. I bought Pat's and it is worth the price. Wrestle that cutter around a few times hooking and unhooking and the price won't matter.
Terry
   / L3400HST Price / Usage / Sanity check #56
I second the Pats suggestion. Best money you will ever spend on your tractor. Not worth mucking with implements without it IMHO.
Does your 3 PT not move at all until you hit about 6? Or does your brush cutter not lift off the ground until after 6 to 8?
If it is the first then it is an adjustment issue. Believe there was a post here on how to adjust the 3PT lever. If it is a the latter then you have probably set your top link to be too long - shorten it up a bit. You want it short enough so that you have a couple inches that you can raise the cutter without it coming off the ground - but that is about it.
Sukup 8R Subsoiler (A59814)
Sukup 8R Subsoiler...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
Hustler super Z zero turn (A56859)
Hustler super Z...
