L3400 will it run a square baler?
   / L3400 will it run a square baler? #1
bigiron1974
WV
Talking with a friend tonight. He said it wouldnt run a square baler. Will it?
   / L3400 will it run a square baler? #3
I think it would be all that it could do and you wouldn't need but the smallest models.
Most of them will need a minimum of 35 PTO horsepower which would equate to about a 45 engine.
   / L3400 will it run a square baler? #5
I'd say it would be at the small side for a square baler. Just barely perhaps.
You guys are probably right, but I am think I might at least give it a shot. Thanks for responding
   / L3400 will it run a square baler? #7
it is hard to believe it takes much hp to run a bailer but I think you need lots of wieght. When the plunger is moving it pushes the bailer back and forth and the tractor needs to take all this abuse.
Rob
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
LOOK! (A53342)
LOOK! (A53342)
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
