L3400 sight glass leaking
   / L3400 sight glass leaking #21
Same story as everyone else---tractor had about 125 hours on it--saw oil leak on shop floor. Found sight glass area to be the problem. Touched the clear plastic glass and it fell off in my hand. The replacement one is of a different material and hopefilly does not have the same problem.
   / L3400 sight glass leaking #22
I did my annual maintenance this past weekend. I ordered a new sight glass when I ordered everything else. I replaced it after I drained the hydraulic fluid. I inspected the old one and the only signs of wear were on the outer edges of the rubber gasket. No problems otherwise.
This was an L3400 HST with 240 hours.
   / L3400 sight glass leaking #23
I found the plastic plug was cracked. Maybe it was over tightened at the plant. Any way, there is now a 3/4" pipe plug in there with a touch of thread seal. I'm shocked it wasn't some metric plug.
I made a dip stick form a welding rod to check the oil from the fill hole in the rear. I'd rather spend a minute to check the oil that way than risk another hydraulic spill.
PTO cable, your next!
Ditto for me. Mine was dripping & I thought it was loose; the threads had cracked. $40 for a new one (2022), nope. A 3/4"
threaded PVC plug works fine. I fill it until fluid weeps from the bottom of the hole, put in the plug & add a gallon.
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
BED FROM 2024 FORD F250 SUPER DUTY (A58018)
BED FROM 2024 FORD...
207010 (A55853)
207010 (A55853)
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
