L3400 Rear Hydraulics
   / L3400 Rear Hydraulics #1
IAFoodPlotter
Kubota L3400DT
I recently purchased a 2008 Kubota L3400DT and discovered it didn't have rear hydraulics. Didn't know it was an option I guess. So, if i take it to a dealer, can that be added? Any idea how much?
Thanks for any info
   / L3400 Rear Hydraulics #2
Yes, they can be added, but I don't know the cost for sure. Mine came with rear remotes, so I didn't have to ask. Good luck.
   / L3400 Rear Hydraulics #3
when i was thinking of buying a kubota cab tractor, the rear remotes cost $900 for the first and $450 for each additional
that was a few months ago.
   / L3400 Rear Hydraulics #4
I had one added when I got My L3400 in 2005. I don't remember the exact price but $900 sounds about right. It attaches to the ROPS as shown in pic. I added the bread pan above it for my gloves and shears in summer.
Thanks for the info and pic! Looks like i'll be calling my Kubota dealer on Monday.
   / L3400 Rear Hydraulics #6
Depending on the implement(s) you will be using the Hyd for, if the implements have their own, "open" valve, extension hoses from the "power beyond" valve will do just fine and be WAY cheaper.
I just end up tying the valve back with a bungie anyway, for all of the inplements that use HYD power on my 3710. (splitter, chipper)
If you are looking to power a cylinder or two, back there, you will need a seperate valve.
$959 to be exact and I had the dealer install it last week. Brought it home to do some work and the 3pt doesn't move. Dealer is looking at it as I type. Oh well, guess I can wait a little longer to get started on my plots.
   / L3400 Rear Hydraulics #9
Oh Man, it is always something. Hope they get it fixed pronto. Good luck.
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
