L3400 question
/ L3400 question #1
blkdak
Bradford Co. Pa
Kubota L3400
The throttle lever goes extremely hard on my L3400. Are any other L3400 owners experiencing this problem? Does anybody know of a fix?
/ L3400 question #2
My L3400 is the same way, but then, so is My Ford 1910.
I think you can adjust the friction nut but I have not tried it. Take a look under there. I assume they make it hard so you don't bump it or it does not vibrate to a different setting.
I guess I'm so used to the Ford throttle lever that I never even though about the L3400. /forums/images/graemlins/smirk.gif
/ L3400 question #3
It's always hard to quantify what "extremely hard" is from one person to another, but mine has seemed a bit stiff, too. And since I'm too lazy to try and adjust it /forums/images/graemlins/grin.gif, I just live with it. I only have to use it two or three times per seat session anyway.
/ L3400 question #4
I agree..I wouldn't call it extremely hard, but it is quite stiff. I figure also that its this way so that it doesn't vibrate out of position or get bumped easily. Only time I ever use it is when running the PTO, otherwise I use the foot throttle. Its got me thinking though...there must be a tension adjustment of some sort on it, I'll have to check it out.
...Tony
/ L3400 question #5
Yeah, it's a bit stiff, but if looser I expect it might not "hold" with the diesel vibration, rough terrain, etc.
/ L3400 question #6
The friction control is straight below the throttle lever and two 12mm wrenches will fix it right up to your taste. I adjusted mine several weeks ago, I was always bumping it too much or not enough.
/ L3400 question #7
Thanks Wushaw...I had a feeling someone would chime in on this before I had a chance to look!! /forums/images/graemlins/wink.gif
...Tony
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
John Deere 54 Manure Spreader (A66408)
John Deere 54...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
