Oil & Fuel L3400 oil change frequency.....
/ L3400 oil change frequency..... #1
Scott in IN
Indiana
Kubota L3400
Per Kubota you are to change the oil every 200 hours. I put maybe 50 hours per year on my tractor (mainly snow plowing and bush hogging) so should I change the oil once a year at 50 hours our wait a couple of years and change it at 200?
/ L3400 oil change frequency..... #2
Change the oil at least once a year no matter how many hours.
/ L3400 oil change frequency..... #3
What Shimon said would be the best oil change plan when you put little hrs on your tractor.
/ L3400 oil change frequency..... #4
I'm in the same boat as you - about 50 hrs per year. I did the full 50 hr service at the one year mark. From now on unless I hit the next maint hr interval I will at minimum change the engine oil/filter once a year and do all the other fluids and filters ever other year.
/ L3400 oil change frequency..... #5
The base concept behind changing your oil once a year regardless of hours (milage) is that water is one of the contaminants that reduce the lubrication effectiveness of oil. Water condenses inside all gas/diesel engines due to temperature / humidity variations. Engines that are run frequently, "boil off" this condensation regularly. So it is less of a problem. And of course, engines that are run frequently, also get more hours / yr. So they would probably get the oil changed yearly anyway :)
AFAIK the auto industry's 12,000 mile oil change is based on the average car being driven roughly 1,000/mo. In other words -- a yearly oil change interval.
Talon Dancer
/ L3400 oil change frequency..... #6
My manual for the L2800/L3400 shows oil changes at every 100 hours not the 200 it shows on the website. If you don't put a 100 hours a year on it I would change oil/filter once a year. See Talondancer's post about moisture.
/ L3400 oil change frequency..... #7
Ditto what Shimon said..
200hrs or 1/year minimum.. whichever comes first.
Don't want that old oil setting in there with all the acids and contaminants.. etc..
Soundguy
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
