Oil & Fuel L3400 oil change frequency.....
   / L3400 oil change frequency..... #1
Scott in IN
Bronze Member
Indiana
Kubota L3400
Per Kubota you are to change the oil every 200 hours. I put maybe 50 hours per year on my tractor (mainly snow plowing and bush hogging) so should I change the oil once a year at 50 hours our wait a couple of years and change it at 200?
   / L3400 oil change frequency..... #2
Change the oil at least once a year no matter how many hours.
   / L3400 oil change frequency..... #3
What Shimon said would be the best oil change plan when you put little hrs on your tractor.
   / L3400 oil change frequency..... #4
I'm in the same boat as you - about 50 hrs per year. I did the full 50 hr service at the one year mark. From now on unless I hit the next maint hr interval I will at minimum change the engine oil/filter once a year and do all the other fluids and filters ever other year.
   / L3400 oil change frequency..... #5
The base concept behind changing your oil once a year regardless of hours (milage) is that water is one of the contaminants that reduce the lubrication effectiveness of oil. Water condenses inside all gas/diesel engines due to temperature / humidity variations. Engines that are run frequently, "boil off" this condensation regularly. So it is less of a problem. And of course, engines that are run frequently, also get more hours / yr. So they would probably get the oil changed yearly anyway :)
AFAIK the auto industry's 12,000 mile oil change is based on the average car being driven roughly 1,000/mo. In other words -- a yearly oil change interval.
Talon Dancer
   / L3400 oil change frequency..... #6
My manual for the L2800/L3400 shows oil changes at every 100 hours not the 200 it shows on the website. If you don't put a 100 hours a year on it I would change oil/filter once a year. See Talondancer's post about moisture.
   / L3400 oil change frequency..... #7
Ditto what Shimon said..
200hrs or 1/year minimum.. whichever comes first.
Don't want that old oil setting in there with all the acids and contaminants.. etc..
Soundguy
8' GREEN CHAIN LINK FENCE (A51244)
8' GREEN CHAIN...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
20' Sea Container (A50774)
20' Sea Container...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
