L3400 Hydro Leak found, advice on fixing
   / L3400 Hydro Leak found, advice on fixing #1
vulcancowboy
Duncannon, Pennsylvania
Kubota L3400 HST
So, I think I finally found the source of my hydro leak. Initially thought it was coming from the vent under the seat, but upon further exploration it appears to be coming from the joint where the hydraulic case cover is bolted onto the transmission (see breakdown).
My question is what type of sealant should I use to seal this connection? Something like Kubota: Acid-Free Grey Silicone Gasket, Part # 07935-60074? Kind of expensive at $44 per tube, but if that is the best choice, I'll spring for it.
Any advice/recommendations appreciated!
   / L3400 Hydro Leak found, advice on fixing #2
When I first got my L3400 HST, 2005, the dealer replaced the 3 pt valve with one that does not jerk. They sealed it with the grey silicone stuff and it is still fine.
   / L3400 Hydro Leak found, advice on fixing #3
Ditto, with everything he said. ^^^
Would the Permatex Ultra Grey work, or should I get the Kubota product?
   / L3400 Hydro Leak found, advice on fixing #5
I don't know enough to answer that. If it was me I'd use the Kubota product. Maybe someone smarter about this will answer.
   / L3400 Hydro Leak found, advice on fixing #6
Use the Kubota stuff.
The Kubota product is Three Bond TB1200GAU3Z
ThreeBond - Silicone Gasket | eBay
WPS has it in their catalog also.
Works good used it when I replaced the brake case on the L3130 and by the time I got everything torqued down filled with oil and no problems on cure time.
David
Blue Bird School Bus (RUNS)(TITLE) (A50774)
Blue Bird School...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2015 Volkswagen Jetta Sedan (A50324)
2015 Volkswagen...
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
