Loader L3400 HST Hydraulic Filters
   / L3400 HST Hydraulic Filters #11
My buddy's 3400 had that same problem and he brought it back to his dealer. They found a crack in the return hose and fixed it for free because they said there was a recall on it.
   / L3400 HST Hydraulic Filters #12
Sounds as though you will not be needing it BUT...
If you need a 26 mm socket, you can use a one inch, it is almost the exact size as 26 mm. KennyV
I talked with my dealership and they told me the cracked hose is an inherent
problem with the L2800 and the L3400. Factory told them paint on hose was
causing the crack LOL! Dealership says models of tractor below L2800 and above L3400 all have a 90 deg. in the metal suction lines and none the hose crack on these upper and lower models.
Dealerships opinion is the suction vacuum at the 90 deg in rubber hose is
causing the hose to fail; wonder why the don't put a plastic spring inside the
hose hmmm?
Going to put my hose on tractor and get busy have a great day gentlemen
and thanks for all the help.
Kenney
   / L3400 HST Hydraulic Filters #14
i had a problem with the hydrolic line on the right side of my L2800....it was cracked and sucking air....my FEL was working slow and it was all cause it was sucking air....put a new one on and it was good as new......cost about $21 at the dealer.......
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Hustler super Z zero turn (A56859)
Hustler super Z...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
