L3400 extra light plugs ?
   / L3400 extra light plugs ? #11
ARRRG,
Remember finding the wiring harness under the seat in that plastic stuff, beholds the soldered connection of two wires that go to the wires that you describe under the rear fenders that have the "Bayonet?" connectors.
I cut into this wire and installed a switch leg for my two rear lights. Previous threads (Year or so) discussed this. I will look ASAP to identify wire colors / location and hope to post pic.
jw5875
   / L3400 extra light plugs ? #12
ARRRG,
jw5875
Pretty much what I did. I broke the hot lead (yellow with red flecks) to install the switch ( I suspect Kubota lights {I'm sure they sell them for a hellish price} would have the switch right at the light), and ran a short lead from the black male bullet connector to the ground on the light.
Chilly
   / L3400 extra light plugs ? #14
Chilly
The Kubota rear work light is about $ 100.
It only works when the headlights are on but it also has a switch on the light itself in case you do not want it on.
It has a heavy duty bracket that mounts to the ROPS with a u-bolt.
The light itself id very nice quality with a steel housing.
My local dealers were within $ 3.00 of each other on my L3400 HST.
One of them added one rear worklight at no extra cost to seal the deal.
Fortyseven2n
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2005 MACK TRI AXLE DUMP TRUCK (A57192)
2005 MACK TRI AXLE...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
HEAVY DUTY STORAGE RACKS (A54757)
HEAVY DUTY STORAGE...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
