L3400 Directional Signals
/ L3400 Directional Signals #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
May be a stupid question, but I have just noticed that when I turn on my directional signal, the chosen side will flash while the other side will lite up steady. Is this the correct operation for the turn signals?
/ L3400 Directional Signals #2
That's what mine does.
/ L3400 Directional Signals #3
/ L3400 Directional Signals #7
I just read about this the other day in my manual, and I believe that is what it said would occur when you use the direction signals.
/ L3400 Directional Signals #8
If I remember right my 3830 also does this...
/ L3400 Directional Signals #9
I think that it is a Japanese thing. Both of my Massey compacts worked that way also.
OK... I guess that is the way it is supposed to work. The more I think about it I can see a possible reason. If only one light was blinking someone following (or approaching) you might think is was simply a "slow moving vehicle" warning flasher... however with one lit up and the other flashing, it would appear more as a directional signal... Make any sense??
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Mercury Verado 350HP 4 Stroke Boat Motor (A61574)
Mercury Verado...
28in Forks and Frame Mini Skid Steer Attachment (A61572)
28in Forks and...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
