L3400 Directional Signals
   / L3400 Directional Signals #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
May be a stupid question, but I have just noticed that when I turn on my directional signal, the chosen side will flash while the other side will lite up steady. Is this the correct operation for the turn signals?
   / L3400 Directional Signals #2
That's what mine does.
   / L3400 Directional Signals #3
   / L3400 Directional Signals #5
My L2800 does the same.
   / L3400 Directional Signals #7
I just read about this the other day in my manual, and I believe that is what it said would occur when you use the direction signals.
   / L3400 Directional Signals #8
If I remember right my 3830 also does this...
   / L3400 Directional Signals #9
I think that it is a Japanese thing. Both of my Massey compacts worked that way also.
OK... I guess that is the way it is supposed to work. The more I think about it I can see a possible reason. If only one light was blinking someone following (or approaching) you might think is was simply a "slow moving vehicle" warning flasher... however with one lit up and the other flashing, it would appear more as a directional signal... Make any sense??
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
2015 Volkswagen Passat Sedan (A48082)
2015 Volkswagen...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
1998 Chrysler Sebring JXi Convertible (A48082)
1998 Chrysler...
1996 Mack RD688S Cab and Chassis (A50860)
1996 Mack RD688S...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
