L3400 coolant change
/ L3400 coolant change #21
Me too, I'm up for my 200 hour change soon and I bet that anti-freeze has been in there since my tractor was built, pretty sure, in 2005. Too bad I bought it new in Dec. 2006. Won't do that again.
My tractor came from the dealer with the yellow long-life (5 year) antifreeze. It's the same age as yours. I figure to service the cooling system next spring.
/ L3400 coolant change #22
I asked about changing my coolant last year, and finally decided to do it, thought I'd share my experience.
After removing the overflow reservoir, and dumping the coolant out of it, I noticed some tan precipitate on the bottom of it. It washed out easy enough but, I decided to buy demineralized water and flush the entire system. I ended up flushing it three times. I was originally thinking I would just drain it and add the new coolant since the Tractor only has 200 hours and is just over 3 years. I chose not to take off any hoses and just use the drain at the bottom of the radiator. As a result, only 4 of the approximate 6 plus quarts of coolant came out each time I drained it.
As noted in the earlier posts, when I filled it up with the pre mix coolant, it was diluted by the 2 plus quarts of demineralized water that was left over from flushing. I ended up having to drain about 5 cups (done over 3 intervals) of coolant and add full strength coolant to get it to the proper freeze / boil over protection level.
Adams 16T Tender Body (A63688)
Adams 16T Tender...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
