L3400 backhoe
/ L3400 backhoe #1
tomtwiss
Has anyone tried the BH80X hoe on the 3400. Is it a good size for this tractor. Also interested in the Ansung Tomcat tc75, any opinions on each would be appreciated. Thanks,
Tom
/ L3400 backhoe #2
I have a BH80X on my 3400... it is a perfect size for the tractor. I went with the PTO pump setup on the advice of my dealer. Power is good, and you don't have to worry about contamination of your tractor hydraulics from frequent on and off hookups of the hoe.
/ L3400 backhoe #3
Is that a 3-pt attachment? I thought the PTO pump was 3-pt only? I plan on getting a BH for mine eventually and I would like to hear/know more. What is the approx. cost for having one installed and how does it perform?
/ L3400 backhoe #4
My BH80X is installed with a subframe... DO NOT install a 3 pt. backhoe on an L3400!...rear housings have been know to crack... search for some older posts.
/ L3400 backhoe
Is the BH80X superior to the backhoe that kubota installs for the 3400? I believe it is a BH76.
COMPLETE SHAFT (A63291)
COMPLETE SHAFT...
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A59912)
2019 FREIGHTLINER...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
(1) UNUSED 8.3-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 8.3-24...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
