L3400/2800 Hydraulic Drawing
   / L3400/2800 Hydraulic Drawing #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
I put together a rought sketch of my current setup. Am looking to identify the follwing lines:
1) Is this Power Beyond?
2) Return to tank - I think this is the only one I know for sure..
3) No Clue
4) No Clue
Can anyone help me ID these?
If anyone has Visio and would like a copy of this, PM me and I'll send the file over..
   / L3400/2800 Hydraulic Drawing #2
1. yes
2. yes
3.Hydraulic block under r/h step
4.hydraulic block under r/h step
answering some of my own questions.. looks like 3 is return to tank and 4 is in from pump..
so then there are 2 returns to tank? in the kubota manual it states that #2 is from implement (Outlet), and #3 is the Tank Port. what is the difference between Outlet and Tank Port??
   / L3400/2800 Hydraulic Drawing #5
I was looking at some picts of mine since I'm not close to my tractor and it looked to me the they (3 & 4) are flex lines coming off the loader valve to the hydraulic block under the r/h step.
I would figure they both can't be return lines, one of em has to be pressure since the rest go to the loader cylinders.
   / L3400/2800 Hydraulic Drawing #6
hope this helps !!
   / L3400/2800 Hydraulic Drawing #7
tell me what you want to do I will make you a drawing
i want to add a 3 spool open-center stack valve (with pb port) as shown in drawing. does my drawing look correct?
   / L3400/2800 Hydraulic Drawing #9
this would be the correct way...without any backhoe... do you have a back hoe, any other questions email me subzero@mcsnet.ca
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
New Wolverine Skid Steer Root Rake Bucket Attachment 31'' (A53002)
New Wolverine Skid...
