L3400/2800 Hydraulic Drawing
   / L3400/2800 Hydraulic Drawing #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
I put together a rought sketch of my current setup. Am looking to identify the follwing lines:
1) Is this Power Beyond?
2) Return to tank - I think this is the only one I know for sure..
3) No Clue
4) No Clue
Can anyone help me ID these?
If anyone has Visio and would like a copy of this, PM me and I'll send the file over..
   / L3400/2800 Hydraulic Drawing #2
1. yes
2. yes
3.Hydraulic block under r/h step
4.hydraulic block under r/h step
answering some of my own questions.. looks like 3 is return to tank and 4 is in from pump..
so then there are 2 returns to tank? in the kubota manual it states that #2 is from implement (Outlet), and #3 is the Tank Port. what is the difference between Outlet and Tank Port??
   / L3400/2800 Hydraulic Drawing #5
I was looking at some picts of mine since I'm not close to my tractor and it looked to me the they (3 & 4) are flex lines coming off the loader valve to the hydraulic block under the r/h step.
I would figure they both can't be return lines, one of em has to be pressure since the rest go to the loader cylinders.
   / L3400/2800 Hydraulic Drawing #6
hope this helps !!
   / L3400/2800 Hydraulic Drawing #7
tell me what you want to do I will make you a drawing
i want to add a 3 spool open-center stack valve (with pb port) as shown in drawing. does my drawing look correct?
   / L3400/2800 Hydraulic Drawing #9
this would be the correct way...without any backhoe... do you have a back hoe, any other questions email me subzero@mcsnet.ca
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
Case Maxxum 140 (A50120)
Case Maxxum 140...
7099 (A51573)
7099 (A51573)
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
