L3301 tires
/ L3301 tires #11
Perhaps 15% of those who load fill all four tires.
I feel loaded fronts are too much for the front axle and power steering on a Loader equipped tractor. I would only fill the rears.
Someone with a recent RimGuard purchase will give you a price per gallon estimate. Price will vary considerably, depending on your location.
If you add your LOCATION to your T-B-N PROFILE replies to your questions will be more closely tailored to your situation.
/ L3301 tires
1) Counterbalance weight mounted on the Three Point Hitch, usually an implement, is more effective pound-for-pound increasing tractor stability relative to tire ballast.
I use a Box Blade for counterbalance. Other frequent choices are Rototillers and Cultipackers. The tires on my L3560 are inflated with air, as were the tires on my two previous tractors.
Your modest weight / modest horsepower tractor is unlikely to rut dry lawns in 2-WD with R1/ag tires inflated with air without counterbalance mounted.
VIDEOS: https://www.youtube.com/results?search_query=tractor+counterbalance+implements
2) Rear tires should be ballasted 50% to 75% full.
50% for lowest center-of-gravity on hills.
50% to reduce proclivity to rut lawns.
75% for max traction.
These fills would normally be done with the wheels/tires on the tractor.
Sometimes an inexperienced mechanic will fill rear tires 100% while tires are laying flat, in which case there is no air in the tire therefore your tractor has 'zero' suspension and tractor will ride rough.
I figured out the counterweight on the Three Point Hitch, but still need more as I am an aggressive land clearer with the smaller bushes and trees. I am looking at the Box Blade, but it needs some work and its green so I hate to do have to put it on, LOL. I am running 4WD and tearing up the yard like crazy as you can imagine, so was looking at the turf tires but decided against it as they keep picking up nails on my JD 790, as we have constant new houses and building here in south Florida. I think filling the rear tires 50% may be the best way to add weight, or just get the R4 tires, so we shall see...
/ L3301 tires #13
I would not spend the money for Rim Guard in S FL. Instead use plain water which you can do yourself. Watch some youtubes for a "how to do it". Use your box blade for counter weight. You can always hang some weight on the box blade. I laid a 4 x 4 x 60 piece of square tubing across the box blade which helped a lot. I also hung 2 - 50# weights on the ripper bar. If I need more I will cut some rebar 59 inch long and fill the tube up and tac them into place. You can also buy wheel weights for the rear rims of the R1s.
This might be helpful for some of the FL plants.
By a light weight one for your tractor its got a limited lifting capacity.
/ L3301 tires #14
/ L3301 tires
I can find weights for my John Deere pretty easily, but have not seen anything for the Kubota except for the older models. Are they moving away from using them..
/ L3301 tires
1) Increasing the spread of your R1/ag tires will do much more for tractor stability than filling the rear tires with liquid. Spread the wheels/tires first.
2) I would not spend the money for Rim Guard in S FL. Instead use plain water which you can do yourself.
I concur.
VIDEOS: https://www.youtube.com/results?search_query=loading+filling+tractor+tires
Well, one thing, is I have well water and in south florida it has high sulfur and other minerals that rust everything metal it touches. Cant clean, wipe, or sprinkle near the tractors with that water much less put it in the tires.
2020 DRAGON ESP...
Electronic Towable Sign Board (A61166)
Electronic Towable...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2007 INTERNATIONAL 9200I (A60736)
2007 INTERNATIONAL...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
