L3300 kubota clutch replacement
/ L3300 kubota clutch replacement #1
ihateu2
cantonment fl
Kubota L3300 DT GST
I'm wanting to replace the clutch on my L3300 kubota with loader looking for info on what i have to remove to get to transmisson bolts and is it best to leave loader attached to the engine.
/ L3300 kubota clutch replacement #2
You definitely need to remove the loader to make it easier to get to the bolts you need to work with as well as the compnents you need to remove. Should also replace the transmission input shaft seal.
/ L3300 kubota clutch replacement #3
I just finished replacing a dual clutch on a 2002 kubota L3000DT 4 wheel drive. I built some fixtures to support each half and just removed anything that connected the front and rear. I also took my loader off. You can look on youtube for a video I put up under Kubota Tractor or aspiringthomas.
